There is two 45, 40, 36. missing 34, 38, 43, 36, just gets worse... Cant delete art board in order anymore as well.
FIX IT PLEASE!
Hi sung,
Do check with a new document (as suggested above), if the issue persists, check the exact version of Illustrator. Is it 22.0.0 or 22.0.1?
You can check it by clicking Help> About Illustrator.
Om
What OS? Looks like CC2018 by the artboard icons.
Try
Can you reproduce it with the fresh file?
Nitish
Hi sung,
Om
Adobe Fix the Bug on latest update.
Thank you,
Sung
Thanks for the confirmation Sung.
Om
Greetings from the Engineering team!
All I can say is we did not fix anything. Do keep a watch on it and let us know if the issue still persists.
I've got the most up-to-date version and myArtboards are doing the same. Issues around 8,13...
Did you quit and restart Illustrator? Please show a screenshot.
Have tried restarting and opening old files that I know had usable Artboard numbering.
nada.
Loved that
I am also having this issue really making it hard to export eps logo files in different formats
:S sure didn't haha (ill 22.1)
Go to Window > Artboard > Rename your artboards (*in sequence) Example: 1,2,3,4,5,6 and artboard 6 should be in artboard 1 then rename your current artboard 6 to artboard 1 then rename all the rest of your artboards in sequence.
