Using Fill & Sign on a pdf (not pdf form). After entering the text and my signature, I save and the resulting document has the text that I entered in completely different spots within the document. I can solve it by going into Edit PDF but I don't really want to enter text in that mode.
Hi jeanned16004202 ,
Thanks for reporting the issue. We are sorry that you are facing such problem.
Can you share with us more information related to the problem so that we can reproduce the issue at our end:
Looking forward to your cooperation.
Onkesh
Hello - i actually got it to work by reducing the zoom level to 75%, which is strange, so I'm going to still mark this as an issue.
I am using Adobe Acrobat Pro DC Version 2015.023.20056
I navigated to the page in which I wanted to add text, selected Tools/Fill & Sign/ and used the text and sign functions to fill in a form (however this form was not created as a PDF form - just a word document that was converted to pdf). When I click 'Save' the refreshed document placed the text at the top of the page. I went back into the document using the Edit function and physically moved the text boxes back into place. When I saved that version, the text remained and the document looked as it should have.
I have used this function with files from different sources with no issues. This has occurred with multiple versions of this one document which I have received from a different source.
I am uploading the screen capture - however, when I go into this same file and try to recreate the issue, it no longer happens.
Hi jeanned16004202,
Are you still facing this issue?
Please share some sample file at http://cloud.acrobat.com/send or email directly to mrraj@adobe.com
I have a similar issue wit Acrobat Reader XI (for a PC). When I edit a document, making notes for text changes, I save the document, then send it to my colleagues. When they open the file (they are using a MAC), the text changes I made seem to shift to a different part of the sentence.
Please advice with any support.
Hi stevef71782465
Is your reader updated to the latest one?
Is it happening with every PDF? Which version of MAC are you using?
