Hello again.
I'm doing a kind of chronometer using a graph that is drawing lines from the same axis to form a circle.
These lines are drawn with a ticker, with which the effect is as if it were filling the circle.
This exercise is a kind of evaluation, where the user will have limited time to answer a question.
At the moment it works, the chronometer is painted while the conditional I put my ticker lasts.
When the user responds, I have to delete this element from the screen, not the buttons or graphics that the scenario has. If I use removeAllChildren (), in effect, it erases everything on the screen which does not help.
If I put it removeChild (line) it does, however it only deletes the last drawn line. That's why I ask for your help, I do not know how I can erase from the screen the traced lines (which in this case are 360) to launch another question and start again.
I enclose the code used, the same and can serve someone with a similar exercise.
root = this;
var miTicker = createjs.Ticker.on ("tick", rotateDraw);
var color = "# 0fe";
var increment = 0;
function rotateDraw () {
//Process to draw line: Create, origin, properties, increase to paint in another position, turn, paint in stage, define index
line = new createjs.Shape ();
line.x = line.y = 150;
linea.graphics.beginStroke (color)
.setStrokeStyle (10, "round")
.moveTo (0, 0)
.lineTo (0, -145)
root.addChild (line);
root.setChildIndex (line, 0);
// Increment to turn
increment = increment + .5;
// Turn for the line
linea.rotation = increment;
if (increment == 360) {
createjs.Ticker.off ("tick", miTicker);
Thanks as always.
either way. with code:
root = this;
var mc = new createjs.MovieClip();
root.addChild(mc);
var miTicker = createjs.Ticker.on("tick", rotateDraw);
var increment = 0;
function rotateDraw() {
line = new createjs.Shape();
line.graphics.beginStroke(color).setStrokeStyle(10, "round").moveTo(0, 0).lineTo(0, -145)
mc.addChild(line);
mc.setChildIndex
...Copy link to clipboard
instead of use root=this, use a movieclip to add your lines to. then you can just remove the movieclip with you want to remove the lines.
p.s. you have some errors in your code. the first i see is linea is undefined
I put all the code with google translate, I did not realize the error in the translation.
I put the correct code again.
line.graphics.beginStroke (color)
.moveTo (0, 0)
.lineTo (0, -145)
line.rotation = increment;
Thanks for the help, however I do not know exactly how to generate that movieclip you mention. Is it to generate a movieclip on the stage and inside it to put the code that I wrote and only make the movie invisible? Or is it to generate this movieclip dynamically and likewise remove it from the screen?
Again, thank you very much.
root = this;
root.addChild(mc);
var increment = 0;
mc.addChild(line);
mc.setChildIndex(line, 0);
createjs.Ticker.off("tick", miTicker);
// call this when you want to remove the lines
function removeLinesF(){
root.removeChild(mc);
It works!
Thanks a lot!
you're welcome.
