I would like to transfer a layer I draw on adobe draw to adobe sketch is It possible..?
Ko,
You're referring to merging a Sketch Layer and an Image Layer, right? This is actually dragging and dropping layer content between the apps.
When dragging and dropping a layer from Draw to Draw the Draw Layer is editable (it's brought in as an Draw Layer).
But, when dragging and dropping a layer from Draw to Sketch, it's as if you're copying from the clipboard (the Draw layer is brought in as an Image Layer), so the content is not editable. If someone wanted to edit that Draw content that Imag
...Copy link to clipboard
Hi IFatma.
Are you using the most recent (v4.5) iOS versions of Draw and Sketch? And at least iOS 11 on an iPad (you need to be on an iPad to use Slide Over view). If so, you can move Draw layer content to Sketch (it won't be editable but it can be part of your Sketch composition).
Let me know.
Sue.
I haven't upgraded to iOS 11 on my iPad yet, but when I copy/paste from the clipboard, the DRAW to SKETCH layer is editable. The best part about converting it into a Sketch layer is that you can then preserve transparency on that layer.
I hope the "drag across" feature supports it too.
Ko,
But, when dragging and dropping a layer from Draw to Sketch, it's as if you're copying from the clipboard (the Draw layer is brought in as an Image Layer), so the content is not editable. If someone wanted to edit that Draw content that Image Layer would have to be merged down with a Sketch Layer. Make sense?
Are we talking about the same thing?
Sue.
Yes, thank you Sue, I updated my iPad & all the apps.
and it workes
thank you again.
IFatma.
Great. Glad it's all working as it should be.
Sue.
