Hello to everyone , I am just returning to Photoshop after a very long time off and I have to start all over again so please pardon the " stupid" questions that I might be asking all over again. But also please remember that I am a novice at Photoshop.
Question : When I put a photo in Photoshop it goes on the background layer , and when I add a second photo it erases the first clip and it goes on to the background also .
Now if I have three (3) clips in Photoshop how can I get to see then as Layer 3
Layer 2
Layer 1
Background
Thanks very much.
It sounds like you have opened 3 separate documents. You need to combine them into a single document to have layers. I recorded this video that shows different ways that you can combine images into a single document. https://www.youtube.com/watch?v=DgaDPeujU3Y&sns=em
No, when you open two images they are simply open as two separate files, nothing is erased.
Maybe you should abandon the tabbed display and use floating windows to better appreciate this.
Layer 2
Layer 1
Background
One can copy/paste (not a very good option, though), drag/drop, use File > Scripts > Load Files into Stack, …
I probably do not have a complete understanding of how Photoshop works . As I said earlier I have 3 clips in Photoshop , I though that :
Clip -1 was always the BACKGROUND LAYER and then
Clip -2 would show as LAYER _ 2
Clip - 3 would show as LAYER _3
But when I click on CLIP - 2 this now shows as THE BACKGROUND LAYER , ETC ETC.
Thank you , thank you , thank you Theresa J . very well explained . That is exactly what I to know . . . . . how to open three (3) separate individual clip layers.
Nice job and very well done , once again thanks very much.
Love your U tube tutorials Theresa ! ! ! ! . . . . . one more thing while I have your attention.
Under the file menu there is PLACE EMBEDDED and PLACE LINKED , can you please explain the difference between the two ?
Thanks in advance.
Here is my video tutorial with explanation The Difference Between Linked and Embedded Smart Object Layers in Photoshop - YouTube
If you need more help do not hesitate to ask more questions.
Thanks very much to you also Bojan , another awesome tutorial . . . . very good .
Thank you very much.
Hi Theresa , like I said your tutorial is awesome but I am having just a slight problem ,
In demonstration No.1 Tabbed Drag & Drop : When I click on the tab of a clip and try to drag like you said to do , the entire tab along with the clip moves from it position and when I drag into the other image I am not achieving the same effect as you having . . . what am I doing wrong ?
Excellent video. You've solved my issue and now, more importantly, I understand why and how, thanks to you. Thank you again for an exemplary learning video.
You just saved my sanity with your instruction video on how to combine layers form other tabs into one document.
I feel like I have wasted days trying to figure this out.
I couldn't figure out how to write the correct search terms in Adobe help, I guess...
I am also trying to figure out how to combine several timeline frame animations into one file in Animate from Photoshop.
If you can help me, I will be very grateful.
I can't seem to figure out how to port my work over into Animate, so that I can combine all my work into one animation short.
If you don't happen to know, please point me in the right direction, maybe by giving me the correct search terms?
Maybe there is no point in trying to work in Animate?
I just thought it would give me more control and functionality. (?)
I am trying to get my skill level up because I am an artist and software developer working in Augmented Reality and I need to be able to put my art into animations that I can then place into my code, and then share with everyone...in their 'realities'.
Thank you!
I’m glad my video helped you out. Thanks for letting me know. I don’t have much experience with Animate so I recommend you ask your question in the Animate forum. I’m sure someone there can help you out. Here’s the link Adobe Animate
