I'm trying to find out the extra plug in and it just gone. Try to search in the addon's page and can't find also. Adobe discontinued the extra plug in?
Missing also in my Windows Lightroom Classic 7.1 (as I might expect with Windows )
Check the help page for a Plugin download at-
How to transfer photos from iPhoto or Aperture to Photoshop Lightroom Classic CC (Mac OS)
In particular:
Edit: But I wonder How you update Lightroom Classic CC to 5.7 ........I think Adobe need to edit their help page.
In particular:
Are you looking in Plugin Extras?
are you using both a Mac and Windows machine or have you moved from Mac to windows? Can you add the context? if you still have Lr on your Mac, you’ll want to import from aperture first before going to windows.
Hi cmgap, Do you see Aperture Import Plugin in your menu? (Classic v7.1)
My post was in reply to the OP, and I am assuming they are using Mac.
I am Windows only and "Aperture Import" may not be included in my Lightroom Install.
I thought the link might give the OP a chance to install the Plugin.
I'm using windows 10, not mac. But I used to have mac and aperture and lightroom on same mac machine. Now I change to windows, and dont have mac anymore.
So Francisco, why do you need the "Aperture to Lightroom" plugin?
If you are using a Windows PC then you will not have Aperture, or its library, on your PC, to be able to 'Import"..
If you imported from Aperture to Lightroom while you had the Mac, did the Lightroom Catalog show all your photos?
I think we need more detailed information from you to determine what you are trying to achieve.
As I told before, I was a Mac user. Now I'm a Windows user. I used to have Aperture and Lightroom when I was a mac user. Now I still have some libraries in my old mac HD's that are in Aperture, so I would like to use this plugin to import them with adjustments, rate and all pre selection that I made before in the Aperture library.
But as I'm seeing here, the Windows Lightroom version didn't have this extra plugin. So I guess If I want that, I need to go to a Mac machine, do the transfer library from Aperture to Lightroom with the extra Plug in available in Lightroom's Mac version, and then copy the catalog generated to my Windows machine. I think that If I need to do that I will just quit, import the pictures folders to Lightroom and start from beginning. Unfortunally.
Hi Francisco - yes that was why I asked if you still have access to a mac with Lr on it. That is the only way to access the Aperture catalog.
Now I still have some libraries in my old mac HD's that are in Aperture...
You might be able to connect your old mac HD to your windows machine and use it as any external hard drive and yes then use Import to bring the images into your windows machine.
I was not aware of that with my previous replies, sorry.
Correct. But you will then need to open your master catalog in Windows and use the Menu {Import from another Catalog} to merge the Mac Catalog with the Windows Catalog.
Simply doing a standard Import of your files will lose much work- so is not recommended.
Have a read of this link to understand what the "Aperture Import" will do for you-
Moving from Aperture to Lightroom – Lightroom Solutions
A quote from the link:
It’s worth understanding what it will bring into Lightroom:
I have the same issue on Lr CC, Under file I just dont have the plug in menu... any idea why ?
Can you upload a screen shot of your Library > Plugin Extras pull down menu?
