Hey Guys,
I have a component that returns a structure. The structure is
called ContactQuery. ContactQuery has to elements, one called
Results, and one called Success. Results contains the data I want
to loop over. If you try looping over the ContactQuery by using
CFLoop and specify the ContactQuery as the collection, of course it
only loops twice (once for Results, once for Success). How can I
loop over the Results structure withing ContactQuery? You can see
the dump of the structure at:
http://www.digitalswordsmen.com/cfschedule/admin/Create_Tokens_Table.cfm
Attached is the code I have. I am just unsure of the syntax
for looping over the Results section of the structure.
Thank you.
