For me Adobe LightRoom has become unreliable and unstable. On occasion a LR crash has brought down my system.. I expect I am not alone in seeing this.. or perhaps I am just lucky?
Does Adobe engineeering take core dumps? or traces?
System:
Mac OS High Sierra, v 10.13.2
iMac (Retina 5k, 27-inch, Late 2015)
Processor: 4GHz Intel Core i7
Memory: 32 GB
Graphics: AMD Radeon R9 M395X 4 GB
I have a suspicion that LR/Adobe is not handling spawned threads properly to exec plug-ins and external editing. I am toggling in/out of PerfectlyClear (latest version) and Photoshop.
--Eric
EXAMPLE #1 :
Process: Adobe Lightroom Classic [12115] Path: /Applications/Adobe Lightroom Classic CC/Adobe Lightroom Classic CC.app/Contents/MacOS/Adobe Lightroom Classic Identifier: com.adobe.LightroomClassicCC7 Version: Adobe Lightroom Classic [1148620] (7.1) Code Type: X86-64 (Native) Parent Process: ??? [1] Responsible: Adobe Lightroom Classic [12115] User ID: 501 Date/Time: 2017-12-28 19:42:14.691 -0500 OS Version: Mac OS X 10.13.2 (17C88) Report Version: 12 Anonymous UUID: 40D52B55-9408-2C02-7EB9-A1956627E268 Time Awake Since Boot: 440000 seconds System Integrity Protection: enabled Crashed Thread: 38 Worker Thread Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x000000010e4173c0 Exception Note: EXC_CORPSE_NOTIFY Termination Signal: Segmentation fault: 11 Termination Reason: Namespace SIGNAL, Code 0xb Terminating Process: exc handler [0] VM Regions Near 0x10e4173c0: --> __TEXT 000000010e422000-000000010e43e000 [ 112K] r-x/rwx SM=COW /Applications/Adobe Lightroom Classic CC/Adobe Lightroom Classic CC.app/Contents/MacOS/Adobe Lightroom Classic
EXAMPLE #2
Process: Adobe Lightroom Classic [31309] Path: /Applications/Adobe Lightroom Classic CC/Adobe Lightroom Classic CC.app/Contents/MacOS/Adobe Lightroom Classic Identifier: com.adobe.LightroomClassicCC7 Version: Adobe Lightroom Classic [1148620] (7.1) Code Type: X86-64 (Native) Parent Process: ??? [1] Responsible: Adobe Lightroom Classic [31309] User ID: 501 Date/Time: 2018-01-06 18:49:47.636 -0500 OS Version: Mac OS X 10.13.2 (17C88) Report Version: 12 Anonymous UUID: 40D52B55-9408-2C02-7EB9-A1956627E268 Time Awake Since Boot: 690000 seconds System Integrity Protection: enabled Crashed Thread: 60 GetWarpedSourcePipe_B (thread index 3) Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: EXC_I386_GPFLT Exception Note: EXC_CORPSE_NOTIFY Termination Signal: Segmentation fault: 11 Termination Reason: Namespace SIGNAL, Code 0xb Terminating Process: exc handler [0]
Stack backtraces are available
There's not much about either iteration of Lr that I don't know.
I used it for years right up and thru Windows 10 Pro.
I now use them on a new iMac and MacBook Air. (10.13.2)
Lr Classic Ver 7.1 and Lr CC Ver 1.1 + the Mobile app.
That said: I haven't a clue what your post is for. We are not mind readers.
The point of the post is to report a series of crashes that originate from within Lightroom code. ...and to determine if others are encountering similar. .. mind reading not required
This is a Computer problem.
You will find other post similar to your but in the end it comes down to problems with your hardware.
If you don't switch between LR, Perfectly Clear and PS and only have LR open does LR crash?
If you run that P C software or PSby itself do you have any problems?
I believe that the problem occurs as a result of running Edit In (Perfectly Clear) and returning control back to LR. The SEGV fault is likely a thread timing/interaction issue -- just a guess from a quick scan of the backtraces in the coredump. I do not think my hardware is causing the problem. Up until the more recent version of LR and Mac OS, I did not encounter these crashes. Note I will be in contact with Perfectly Clear support as well.
You should report this over at the official feed back forum.
https://feedback.photoshop.com
This is a User to User forum and not really monitored by Adobe.
