SOLVED
Enable Lowercase alphabets in RTE component in touch ui
Avatar
Level 2
Hello Team ,
How to enable Ordered List of lower case alphabets label in custom RTE component. As of now we have only Unordered,Ordered(number labeled),indent and outdent in RTE component, I need to add Alphabets label list in RTE component.
Like above attached snapshot, I need lists in a,b,c.. Can you please anyone guide me to achieve this?
Naveen
1 Accepted Solution
Avatar
Correct answer by
Employee
Avatar
Level 10
We are checking internally for this.
Avatar
Level 10
A Touch UI expert said the following post comes pretty close; instead of a.b.c it adds a background color
http://experience-aem.blogspot.com/2017/05/aem-62-touch-ui-extend-rte-list-plugin-for-adding-selecte...
Avatar
Correct answer by
Employee
Avatar
Level 2
Hi Sree,
Thanks for the post and I tried to use your code for AEM 6.1 and facing an issue like, when I have selected numbered list in touch ui, it takes alphabets list and alphabet list icon is not selected and disabled instead numbered list icon is selected always.
Below is the code I used :
(function ($) {
    "use strict";
    var _ = window._,
        Class = window.Class,
        GROUP = "experience-aem",
        ALPHA_LIST_FEATURE = "alphaList",
        ORDERED_LIST_CMD = "insertorderedlist",
        CUI = window.CUI;
    addPluginToDefaultUISettings();
    var EAEMAlphaListCmd = new Class({
        extend: CUI.rte.commands.List,
        toString: "EAEMAlphaListCmd",
        execute: function(execDef) {
            this.superClass.execute.call(this, execDef);
            var list = this.getDefiningListDom(execDef.editContext, execDef.nodeList);
            if(!list){
                return;
            $(list).attr("type", "a");
    CUI.rte.commands.CommandRegistry.register("_list", EAEMAlphaListCmd);
    var EAEMAlphaListPlugin = new Class({
        toString: "EAEMAlphaListPlugin",
        extend: CUI.rte.plugins.Plugin,
        pickerUI: null,
        getFeatures: function () {
            return [ALPHA_LIST_FEATURE];
        initializeUI: function(tbGenerator) {
            var plg = CUI.rte.plugins;
            if (!this.isFeatureEnabled(ALPHA_LIST_FEATURE)) {
                return;
            this.pickerUI = tbGenerator.createElement(ALPHA_LIST_FEATURE, this, false, this.getTooltip("toggle"));
            tbGenerator.addElement(GROUP, plg.Plugin.SORT_FORMAT, this.pickerUI, 10);
            var groupFeature = GROUP + "#" + ALPHA_LIST_FEATURE;
            tbGenerator.registerIcon(groupFeature, "coral-Icon coral-Icon--textLetteredLowercase");
        execute: function (id, value, envOptions) {
            if (!isValidSelection()) {
                return;
            this.editorKernel.relayCmd(ORDERED_LIST_CMD);
            function isValidSelection(){
                var winSel = window.getSelection();
                return winSel && (winSel.rangeCount == 1) && (winSel.getRangeAt(0).toString().length > 0);
        updateState: function(selDef) {
            var hasUC = this.editorKernel.queryState(ALPHA_LIST_FEATURE, selDef);
            if (this.pickerUI != null) {
                this.pickerUI.setSelected(hasUC);
    function addPluginToDefaultUISettings(){
       var toolbar = CUI.rte.ui.cui.DEFAULT_UI_SETTINGS.inline.toolbar;
        toolbar.splice(3, 0, GROUP + "#" + ALPHA_LIST_FEATURE);
        toolbar = CUI.rte.ui.cui.DEFAULT_UI_SETTINGS.fullscreen.toolbar;
    CUI.rte.plugins.PluginRegistry.register(GROUP,EAEMAlphaListPlugin);
Did this ordered list plugin with lowercase alphabets work for anyone ?
