Hi. I earlier used Flash CS5 but now I use Flash Professional CC due to faulty video export in CS5. Anyhow: Motion Editor now missing, this has been included directly in the timeline, I know.
My problem is that i can't open the Motion Editor panel. I create a movie clip, create the motion tween, select the span and double click. Nothing happens. I try to right click the span, but the option "Refine Tween" simply isn't there... Please help!
Hi. If you are using an early Flash Professional CC version, it was some time before Motion Editor was re-integrated into the application. Can you use a more recent version of Animate CC instead? They can be installed side-by-side if you prefer.
moving to Adobe Animate CC - General forum.
Jonathan,
Where exactly is the Motion Editor in Animate CC 2018?
Hi Kelly,
add a Motion Tween and then double-click it in the layer.
Thanks! I thought that note was important to have in this thread. Also note: double click again to close the "Motion Editor"
