27 Replies Latest reply on Jul 16, 2018 8:59 AM by tonyk16244512
    What is the best Pen Tablet for Photoshop/Illustrator
    mhossey Level 1
      The more I get into design the more I keep seeing digital painting, and hearing about tablets for drawing using pressure sensitive response from the tablet. I've been on wacom and literraly just started researching a bit. I see a bamboo tablet and also an intuos tablet. Any advice for an up and coming designer and which one to buy, what to look for, what not to look for, good/bad experiences and so on?
      Michael
        • 1. Re: What is the best tablet for Photoshop/Illustrator
          JJMack Most Valuable Participant
          They will only run on a windows based tablet.  They will not run on a Windows 8 ARM tablet either.  Adobe only sypports Windows and Mac OS Adobe does have some Tablet Apps but not Photoshop and Illustrator applications.
          • 2. Re: What is the best tablet for Photoshop/Illustrator
            mhossey Level 1
            so your saying I cant use a tablet with photoshop or illustrator? I thought there were specific features inside of these programs to work with tablets, maybe I didnt understand
            • 3. Re: What is the best tablet for Photoshop/Illustrator
              Level 7
              Do you mean a tablet computer (like an iPad) or a drawing tablet (Wacom)?
              I think JJMack meant the former, while you meant the later.
              1 person found this helpful
              • 4. Re: What is the best tablet for Photoshop/Illustrator
                mhossey Level 1
                Ahh, wow I cant believe I didnt catch that difference ha. No I'm talking about Wacom, for painting, drawing etc... not Ipads etc...
                • 5. Re: What is the best tablet for Photoshop/Illustrator
                  Trevor.Dennis Adobe Community Professional
                  If you really want the best, then I guess that has to be the big Cintiq
                  But that's a bunch of dollars.  Most of us use the Intuos, which is perfect for photoshop
                  I have an Intuos4 and have not tried a 5 or Touch, and that's what you'd buy new now.
                  • 6. Re: What is the best tablet for Photoshop/Illustrator
                    In the case I like the Wacom Intuos. A small one if you draw with small amount of hand movement.  If you prefer large sweeping strokes a larger tablet may be in order.  Tablets can be remaped to screen or screens and a small portion of the tablet can be maped to your whole display. So a Large tablet can also work like a small tablet.  Intuos version function about the same the newer one have some real hardware button that can be programmed and customize the user interface a little better then older versions. The actual pen interface has not really change much at all IMO.
                    • 7. Re: What is the best tablet for Photoshop/Illustrator
                      Trevor.Dennis wrote:
                      If you really want the best, then I guess that has to be the big Cintiq But that's a bunch of dollars.
                      A BIG bunch....
                      • 8. Re: What is the best tablet for Photoshop/Illustrator
                        mhossey Level 1
                        Thanks JJ helpful, in my research almost everyone that does any decent size of design is gearing towards the intuos over the bamboo. The cintiq is just stupid expensive so I can rule that out along with the fact I'm more test driving it right now anyways
                        Hey thanks again JJ
                        If anyone else wants to give their 2 cents about bamboo vs intuos go right ahead
                        • 9. Re: What is the best tablet for Photoshop/Illustrator
                          One problem with the big Cintiq is that it has to double as your main monitor — in practical terms at least.  Although I guess if you always use it in horizontal mode, you could still have a big screen behind it.  Heck, why are always looking for an excuse to spend more money on stuff?
                          There must be some truth in the adage ‘He who dies with the most toys wins’.
                          • 10. Re: What is the best tablet for Photoshop/Illustrator
                            Pan Da
                            I have the same question. I use MAC and use adobe on it and want to handdraw and use a Wacom product like Bamboo or Intus. But will the Wacom products work on a MAC?
                            • 11. Re: What is the best tablet for Photoshop/Illustrator
                              No problem using Wacom tablets with OSX as far as I know.   I have used tablets since thew original Graphire, and now use a medium  Intuos 4 and a Cintiq Companion 2.  I always use the Intuos with my main computer.  If I had to replace it now I'd get an Intuos 5 Touch (or whatever they are calling them now.   I am not sure how the Touch features work with OSX however.  With Windows you need 8.1 or 10 to use Gestures.
                              [EDIT]  I have changed the subject line to make it clear this thread is about pen tablets, and not IOS or Android iPad type devices.
                              • 12. Re: What is the best Pen Tablet for Photoshop/Illustrator
                                slashpot Level 1
                                The Wacom intuos & Bamboo are designed to work with Windows and Mac. The Intuos is meant to be the "pro" version, and the Bamboo more for the "pro-sumer', or amateur. The Cintiq is a different beast, but really it's designed for the Pro - with lots of cash!
                                I've had a Graphire and am now using my third Intuos, the Intuos 5 Pen & Touch, small. Frankly the touch part is a bit useless as it makes my drawing go stupid at times, so I have to keep it switched off, but if you're one of those folks that's happy to put on one of those groovy gloves every time it's prolly fine. The tablet part is the best I've used, but be sure to get one of their "Art Pens" to get the most out of it (an extra $80-90). There's also the option of getting a wireless dealie, so you can work without being tethered (another $40-50).
                                The Bamboo range, as far as I can figure, is really quite close to being as good as the intuos in basic operation, and if you're one of those incredibly rare people who doesn't have wads of cash lying around (what's wrong with you weirdo!), or you're a beginner, or both, it's probably a good option, but remember, if you plan on going to an intuos or better anyway, the pens aren't interchangeable. The intuos 5 is also cheaper now, so probably worth it if you can. I imagine Wacom are working on intuos 6 as we speak, so be sure to check it isn't within days of release before splashing your hard-earneds around, as it will make 5s cheaper, and may itself be an unmissable revolution you can't live without.
                                Have fun!
                                • 13. Re: What is the best Pen Tablet for Photoshop/Illustrator
                                  matevžk67716702
                                  Hello, how are you?
                                  Can you suggest me which pen table would be perfect for a beginner? I would like to edit pictures in photoshop, some shadowing, etc.
                                  I was looking at Intuos 5 with art pen, but I cant find this product anywhere. Does it have any other name maybe?
                                  Thank you and best regards,
                                  Matevz
                                  • 14. Re: What is the best Pen Tablet for Photoshop/Illustrator
                                    Wacom do like to keep reinventing themselves, with new product names.  I think the 'Intuos 5 Touch', is now sold as the 'Intuos Pro'.
                                    Intuos Pro Medium Digital Tablet for Drawing on a Mac
                                    I started with Wacom's very first tablet, the Graphire way back, and have used an Intuos 4 for some years now.  I also have a Cintiq Companion 2, but I prefer the Intuos.  I would love an excuse to upgrade to the Pro, but I've found from my Cintiq Companion that gestures can be more of a hindrance than an aid, causing unintended zooms, pans and rotations of the canvas, so I'm sticking with the Intuos 4.
                                    Mine is a Medium which is a good compromise between taking up a ton of desk space, but still be big enough for fine control.  I also love the Express Wheel on the Intuos, which I use exclusively for brush size.
                                    We see way too many posts from people with Chinese knock off tablets where the drivers never work properly, so I'd steer clear of them.
                                    Some people use the pen for everything, but I like to use the mouse for things like clipping paths.
                                    • 15. Re: What is the best Pen Tablet for Photoshop/Illustrator
                                      matevžk67716702 Level 1
                                      Hello,
                                      thank you for answering. I will do on my mac book pro laptop 13". Do you think small version of intuos pro would be ok?
                                      • 16. Re: What is the best Pen Tablet for Photoshop/Illustrator
                                        SmashingWall Level 1
                                        I agree with Huion tablets are VERY cheap and excellent quality & very light weight to carry easily anywhere (but screen size small), Wacom Intuos, Wacom Bamboo has (resolution of 2540 LPI) & Ugee 1910B is great (if need large & perfect screen size of 16:9), for detailed & comparison tablets check here: bestofgoods.com/top-10-best-tablets-drawing-artists/
                                        • 17. Re: What is the best Pen Tablet for Photoshop/Illustrator
                                          Spend some time on this forum, and you'll see the number of issues (often as not unresolved) we get asked about with non Wacom tablets.  That's not to say Wacom tablets never have issues, but we can usually fix them.
                                          • 18. Re: What is the best Pen Tablet for Photoshop/Illustrator
                                            vixler
                                            The Intuos 5 is now called Intuos Pro. Here is a post from Wacom about it.  I
                                            I think for beginners one of the Intuos non-pro tablets is a good deal. I have a Huion, I recommend that too for the size and price, though I know some people have a hard time installing the driver. Here is info about Intuos tablets there is also info about non-Wacom.
                                            Another good source of info is YouTube, where you can see people using just about any tablet.
                                            • 19. Re: What is the best Pen Tablet for Photoshop/Illustrator
                                              blisster138 Level 1
                                              These days, the "best tablet" for Photoshop or Illustrator is really defined by how you might use it. There are a variety of options ranging from Microsoft's Surface tablet and computer line to Wacom's recent additions to the Cintiq family to the iPad Pro and it's various complimentary applications. Per your original question: Bamboo is Wacom's entry-level line, Intuos is more in their professional range, and the Cintiq is aimed at professional digital painters and illustrators. Just getting started a Bamboo should work okay, but I'd recommend bumping up to the smaller Intuos tablet if possible. It's going to provide better pressure sensitivity and a good feel for creating digital art.
                                              If you find yourself having a rough time acclimating to the pen or using it while not having to look at the screen, you might be a good candidate for a Cintiq. Otherwise, you may find your workflow lends itself to using a tablet like the Surface or an iPad Pro to do initial creation of your drawings/painting, then you can transition over into Photoshop or Illustrator to enhance your digital works in post-production.
                                              I currently use a Wacom Intuos Pro M (which is the medium size), along with a mouse as needed for quick edits, along with an iPad Pro 9.7. Sometimes I'll initiate work on the iPad then move over to Photoshop to manipulate the work further. I've been looking at picking up a Surface Pro because that could save a step but I'm unsure how different the pen will feel. Ultimately, try out some different options and see what fits your workflow and process best. Some of the best designers I know do all their digital illustration work using nothing but the mouse so as with everything, it all really depends. Good luck!
                                              • 20. Re: What is the best Pen Tablet for Photoshop/Illustrator
                                                Gingerdeer Level 1
                                                Dear Michael,
                                                This is obviously personal but I can share my choices... The Intuos Wacom is solid and I've been using it for years.
                                                I wouldn't risk getting less than the Intuos, I've had a few BUT have never noticed any benefit of having the latest. Sure you can have 2000 levels of pressure instead of 1000 but I've never felt a difference. I think it peaked at Intuos 4 which had little LCD screens on it to say what the shortcut is. The new ones have an onscreen display I'm not a fan of. Perhaps you could find a 2nd hand deal?
                                                Cintiq is over-rated and expensive.
                                                I heard great thing about the iPad pro, Apple Pencil and AstroPad so I bought it and I'm really impressed. My only words of caution is with cintiq or iPad your posture changes. When you work on the screen directly you hunch over, with an Intuos (or similar) you can sit up right and look at the screen. When working long hours this is an important consideration.
                                                I'd seriously consider an iPad since it could suit your needs and you could use it independently too.
                                                All the best, Oscar
                                                • 21. Re: What is the best Pen Tablet for Photoshop/Illustrator
                                                  zacd Level 1
                                                  I know this is not a Drawling Tablet answer, but my HP Spectre 2016 has worked wonders, since I can draw straight on the screen. Hope you find your answer!
                                                  • 22. Re: What is the best Pen Tablet for Photoshop/Illustrator
                                                    teachbit Adobe Community Professional
                                                    I am working with a Wacom Intuos size M and I am completely happy. The Bamboo Tablett is more for the hobby user, as the pencil is not that ergonomic as the Intuos one, where you can draw for hours without tiring your hand. You just have to get used to draw on the tablet while looking on the screen, but you get accustomed quickly. I am a Wacom  fan using their tablets since 25 years.
                                                    • 23. Re: What is the best Pen Tablet for Photoshop/Illustrator
                                                      This is interesting. A real artist comparing different levels and ages of Wacom tablets. His findings might surprise you.
                                                      I used the original Graphire for many years before upgrading to an Intuos 4, and truth be told, there was not a massive difference in their functionality.  As the video above says, you are going to be very hard pressed to tell the difference between 1000 and 2000 pressure levels.  Can you make a line with your tablet that produces a smooth increase in line thickness using pressure alone?
                                                      • 24. Re: What is the best Pen Tablet for Photoshop/Illustrator
                                                        I agree about the levels of  pressure  It more about the transition between levels the feel of it that is important.  The number of levels is not a big deal. A  1000 levels is more than needed IMO.
                                                        However he only use sketchbook and small pen tips and flippantly stated application make no difference.  I can not agree there.  Photoshop with a large high resolution document  zoomed out to fit on screen with a large brush tip and  spacing 1% will have big lag.  Make it a mixer brush you will see a brush stroke  will take forever and a day.  The Application's Design, Brush engine, document size support and settings  can make a very big difference.   It is easy to overtax your machine using Photoshop. It is an image editor with  painting added on. Photoshop always work on the full size document and then scales the result to the zoom level for viewing.  A Painting application may work much differently for a better user experience by painting on the small scale image and work on the full size image in the background.
                                                        IMO the Application may make a world of a difference when it come to performance and lag. My first intuos 1 was a 12" tablet tool big and it most likely would still work if you could get a COM device driver for it.   You would most likely need to regress to Windows 95 for that. Wacom now a days support USB and wireless connection of their tablets.  They dropped support for my intuos 1.
                                                        • 25. Re: What is the best Pen Tablet for Photoshop/Illustrator
                                                          mottib91448129
                                                          I know this thread is old but I thought I will post anyway.
                                                          Look for:
                                                          XP-Pen
                                                          Huion
                                                          Artisul (probably the best in this list)
                                                          Those companies make some amazing tablets and on screen drawing tablets (like the Cintiq). The one thing they do not support is pen tilt but other than that their quality is amazing. Many Wacom users say that their paralex and straight drawing lines are better than Wacom.
                                                          Those tablets are practically a third of Wacom price.
                                                          Allocate some time, make a cup of coffee, sit down and watch some Youtube reviews. You will be amazed. Many of those reviewers are professional animators and many have one of those tablets as their main driver drawing hours every day. Unfortunately, no Photo editing reviews to find anywhere. I looked.
                                                          But, if those tablets are good for animators they are definitely excellent for photo editing.
                                                          I hope that helps.
                                                          • 26. Re: What is the best Pen Tablet for Photoshop/Illustrator
                                                            D Fosse Adobe Community Professional & MVP
                                                            Yes, I know this post is a month old, but I didn't pay attention back then.
                                                            The difference between 1000 and 2000 levels is the difference between 10 and 11 bit depth. Considering your monitor has 8 bit depth (or at most 10) - no, there's no possible way you can tell the difference, even theoretically.
                                                            What will make a difference, however, is if some of those levels can be set to touch, no press. In other words, rest the pen on the surface - but no click until you press. The cheaper "Intuos Pen and Touch" that I had, and threw away in disgust, couldn't do that. The Intuos Pro, as I understand, can.
                                                            I've come to realize that my main objection to the Intuos Pen and Touch has a name: parallax error. It's completely equivalent to rotating a camera and lens, and getting a planar shift as a result. As your hand rotates around the wrist - the position of the cursor shifts. It ends up in a different place than you thought. To me, this made the tablet completely useless for precision work.
                                                            Say what you will about a mouse, but it doesn't do that. It sits dead still until you move it. It doesn't click until you click.
                                                            • 27. Re: What is the best Pen Tablet for Photoshop/Illustrator
                                                              tonyk16244512 Level 1
                                                              Wacom tablet is one of the best cheap drawing tablets available under $100. The tablet is also compatible with Mac and Windows Laptop too. It also includes free downloadable software.
