I edited a large document for a week in Adobe Reader 10.0. I saved regularly to the original filename. I then closed the file and Adobe removed it (and another document open with it) immediately from the recent document list. I can see large files in the temp folder which clearly represent saved versions of these files. There is nothing in the Autosave folder under users/appdata/local/adobe/10.0. There was no autosave set by me, indeed, since I was saving regularly. Where is the default autosave and how can I get this crucial file, worth more than a week of constant work, back? The file was sent to me in a zip file and I stored it on an external hard drive, which I was saving back to, since it was very large. The file appears not to have been overwritten at all still bearing its original creation date - and yet Reader never prompted me for any 'save as' route and consistently appeared to save the file as I asked it to.
If this is an Adobe fault, it is a very serious one and the company should fix it now. The changes were annotations. There must be a way to open or view the temp files' content. Can any Adobe staff reading this please advise how I can access the data in the temp files, since this appears the only data saved?
Just an update - I found the Autosave feature was indeed enabled as default - yet the Autosave file is empty. I was offered NO recovery document after closing and re-opening and thus I need to open the temp files. PLEASE let me know how this is done!
Info: Vista and Reader X are unsupported. Adobe will not fix this.
Reader writes Acr*.tmp files contains information in progress. These are not auto save files Nor anything to recover from. They are deleted on a normal close, suggesting you actually experienced a crash.
Since you say you saved, possibly it was saving but to a different folder. Repeat the test and check this out. After “save” use Ctrl+D to see the file location.
A tip: before starting my suggested test, duplicate the PDF under a new name AND USE THE NEW COPY TO TEST so that you don’t accidentally overwrite your one good save somewhere.
