When I want to use this Accordion Widget with Overlight Items below unchecked,
because I want that when it pops out the footer will move too...
I have the problem, that when my Text goes about over 10 Lines the whole Website jumps and moves a little bit
when I open the Widget Tab in Webbrowser. On the other Tabs with less Text no move!
Thank you guys, I am a print nut graphic designer 😉
Muse looks nice but some little things hard to get into it. I keep on learning.
Could you give us a link?
You may publish the site temporarily and for free, if you use „Businesscatalyst“ from the „Publish“ button top right of Muse‘s application window.
I assume, the shifting is caused by the fact, that opening the accordion widget makes the page higher than the browser window and the scrollbar appears. You may customize this behaviour in your „Site Properties“.
