How do I draw a rounded border? When I searched for solutions, a lot were about how to draw rounded rectangles or rounded corners but I want to insert a rounded border. Thanks.
Sorry, but I misunderstood what you are looking for. Try this:
Have a look at the Shape Selection tool (Keyboard short-cut U).
There are many shapes, e.g. Crescent Moon, etc.
Thank you. There are all sorts of fancy shapes but none that is a rounded border.
Thank you, it works.
You're welcome. Glad to help.
1. Select the Rounded Rectangle tool. Set Radius (size of rounded corner) to a large value (in this example I used 80 px).
2. Draw out rectangle, creating a new layer. Ctrl-click the layer to select just the shape and delete the layer (for purposes of the example I just turned off its visibility).
3. Create a new blank layer and Edit>Stroke. I used a value of 50 px. Location Inside gave the best result; Center and Outside gave corners that were not quite well rounded.
Thank you but I do not think you have finished your sentence? Step no 3.... I selected Edit>Stroke and there there another rounded rectangle but what then??
I should have mentioned to enter the stroke size (width of the border).
Hatstead did in his instructions (same as my instructions).
Let us know if you have success.
