3d tool's is Non-clickable button In Photoshop
Jan 14, 2018 Jan 14, 2018
Hello,I have a problem with the 3d tool's. its not open and Nor does it appear as a push button.. What do i need to do ?
670
Community Expert , Jan 14, 2018 Jan 14, 2018
Photoshop is not seeing your Graphics Processor ( GPU) Open GL functions and it needs the GPU functions for 3D.
Go to Photoshop >Preferences > Performance and see if you can turn on Use Graphics Processor. If you can, start a new document and try 3D
if you can't :
1. Check your system meets the minimum requirements (two links below)
Photoshop system requirements
Photoshop graphics processor (GPU) card FAQ
2. Use the steps here to troubleshoot the GPU
Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues
Adobe
Hi
First check your document is in RGB mode (Image >Mode)
If it is, can you go to Help >System info and click on copy. Then paste the info here. It will help us to see if there is anything in your set up preventing you from using 3D
Dave
Adobe Photoshop Version: 19.0 20171103.r.190 2017/11/03: 1143799  x64
Number of Launches: 105
Operating System: Windows 7 64-bit
Version: 7 SP1 6.1.7601.24000
System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 3591 MHz
Built-in memory: 16252 MB
Free memory: 7920 MB
Memory available to Photoshop: 14436 MB
Memory used by Photoshop: 60 %
Surface Dial: Enabled.
Alias Layers: Disabled.
Modifier Palette: Disabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
The GPU Sniffer crashed on 14/01/2018 at 15:50:04
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
OpenGL Drawing: Disabled.
OpenGL Allow Old GPUs: Not Detected.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=0
NumGLGPUs=0
NumNativeGPUs=0
License Type: Subscription
Serial number: 90970775374973485581
GUIDBucket:
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
Temporary file path: C:\Users\admin\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
  E:\, 931.4G, 551.6G free
  C:\, 223.3G, 75.6G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
Installed components:
   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
   ACE.dll   ACE 2017/09/19-18:51:44   79.586793   79.586793
   AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
   AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
   AdobeOwl.dll   Adobe Owl   5.2.11
   AdobePDFL.dll   PDFL 2017/09/01-01:08:01   79.239219   79.239219
   AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
   AdobeSVGAGM.dll   AdobeSVGAGM   79.586793   79.586793
   AdobeXMP.dll   Adobe XMP Core 2017/07/13-01:06:39   79.160924   79.160924
   AdobeXMPFiles.dll   Adobe XMP Files 2017/07/13-01:06:39   79.160924   79.160924
   AdobeXMPScript.dll   Adobe XMP Script 2017/07/13-01:06:39   79.160924   79.160924
   adobe_caps.dll   Adobe CAPS   10,0,0,6
   AGM.dll   AGM 2017/09/19-18:51:44   79.586793   79.586793
   ahclient.dll    AdobeHelp Dynamic Link Library   3.0.0.6
   AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
   amtlib.dll   AMTLib (64 Bit)   10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8)   1.000000
   ARE.dll   ARE 2017/09/19-18:51:44   79.586793   79.586793
   AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
   AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
   Bib.dll   BIB 2017/09/19-18:51:44   79.586793   79.586793
   BIBUtils.dll   BIBUtils 2017/09/19-18:51:44   79.586793   79.586793
   boost_date_time.dll   photoshopdva   11.1.0
   boost_filesystem.dll   photoshopdva   11.1.0
   boost_signals.dll   photoshopdva   11.1.0
   boost_system.dll   photoshopdva   11.1.0
   boost_threads.dll   photoshopdva   11.1.0
   cg.dll   NVIDIA Cg Runtime   3.0.00007
   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
   CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
   CoolType.dll   CoolType 2017/09/19-18:51:44   79.586793   79.586793
   CRClient.dll   Adobe Crash Reporter Client DLL   1.6.1.0
   dnssd.dll   Bonjour   3,0,0,2
   dvaaudiodevice.dll   photoshopdva   11.1.0
   dvacore.dll   photoshopdva   11.1.0
   dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
   dvamarshal.dll   photoshopdva   11.1.0
   dvamediatypes.dll   photoshopdva   11.1.0
   dvametadata.dll   photoshopdva   11.1.0
   dvametadataapi.dll   photoshopdva   11.1.0
   dvametadataui.dll   photoshopdva   11.1.0
   dvaplayer.dll   photoshopdva   11.1.0
   dvatransport.dll   photoshopdva   11.1.0
   dvaui.dll   photoshopdva   11.1.0
   dvaunittesting.dll   photoshopdva   11.1.0
   dynamiclink.dll   photoshopdva   11.1.0
   ExtendScript.dll   ExtendScript 2017/08/31-12:13:14   81.1133690   81.1133690
   icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   igestep30.dll   IGES Reader   9.3.0.113
   imslib.dll   IMSLib DLL   10.0.0.22
   JP2KLib.dll   JP2KLib 2017/08/23-01:11:25   79.267771   79.267771
   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
   libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
   libmmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
   LogSession.dll   LogSession   7.4.1.60.45263
   mediacoreif.dll   photoshopdva   11.1.0
   MPS.dll   MPS 2017/09/01-01:08:01   79.586120   79.586120
   pdfsettings.dll   Adobe PDFSettings   1.04
   Photoshop.dll   Adobe Photoshop CC 2018   19.0
   Plugin.dll   Adobe Photoshop CC 2018   19.0
   PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   8.0.0
   PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   8.0.0.55
   PSArt.dll   Adobe Photoshop CC 2018   19.0
   PSCloud.dll                                                   1.0.0.1
   PSViews.dll   Adobe Photoshop CC 2018   19.0
   SCCore.dll   ScCore 2017/08/31-12:13:14   81.1133690   81.1133690
   SVGRE.dll   SVGRE   79.586793   79.586793
   svml_dispmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
   tbb.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
   TfFontMgr.dll   FontMgr   9.3.0.113
   TfKernel.dll   Kernel   9.3.0.113
   TFKGEOM.dll   Kernel Geom   9.3.0.113
   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
   updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
   VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
   VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
   WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
   wu3d.dll   U3D Writer   9.3.0.113
Required plug-ins:
   3D Studio 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Accented Edges 19.0 - from the file “Filter Gallery.8bf”
   Adaptive Wide Angle 19.0 - from the file “Adaptive Wide Angle.8bf”
   Angled Strokes 19.0 - from the file “Filter Gallery.8bf”
   Average 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Average.8bf”
   Bas Relief 19.0 - from the file “Filter Gallery.8bf”
   BMP 19.0 - from the file “Standard MultiPlugin.8bf”
   Camera Raw 10.1 - from the file “Camera Raw.8bi”
   Camera Raw Filter 10.1 - from the file “Camera Raw.8bi”
   Chalk && Charcoal 19.0 - from the file “Filter Gallery.8bf”
   Chrome 19.0 - from the file “Filter Gallery.8bf”
   Cineon 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Cineon.8bi”
   Clouds 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Clouds.8bf”
   Collada 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Color Halftone 19.0 - from the file “Standard MultiPlugin.8bf”
   Colored Pencil 19.0 - from the file “Filter Gallery.8bf”
   CompuServe GIF 19.0 - from the file “Standard MultiPlugin.8bf”
   Conté Crayon 19.0 - from the file “Filter Gallery.8bf”
   Craquelure 19.0 - from the file “Filter Gallery.8bf”
   Crop and Straighten Photos 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “CropPhotosAuto.8li”
   Crop and Straighten Photos Filter 19.0 - from the file “Standard MultiPlugin.8bf”
   Crosshatch 19.0 - from the file “Filter Gallery.8bf”
   Crystallize 19.0 - from the file “Standard MultiPlugin.8bf”
   Cutout 19.0 - from the file “Filter Gallery.8bf”
   Dark Strokes 19.0 - from the file “Filter Gallery.8bf”
   De-Interlace 19.0 - from the file “Standard MultiPlugin.8bf”
   Dicom 19.0 - from the file “Dicom.8bi”
   Difference Clouds 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Clouds.8bf”
   Diffuse Glow 19.0 - from the file “Filter Gallery.8bf”
   Displace 19.0 - from the file “Standard MultiPlugin.8bf”
   Dry Brush 19.0 - from the file “Filter Gallery.8bf”
   Eazel Acquire 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “EazelAcquire.8ba”
   Entropy 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Export Color Lookup Tables 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Export3DLUT.8be”
   Extrude 19.0 - from the file “Standard MultiPlugin.8bf”
   FastCore Routines 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “FastCore.8bx”
   Fibers 19.0 - from the file “Standard MultiPlugin.8bf”
   Film Grain 19.0 - from the file “Filter Gallery.8bf”
   Filter Gallery 19.0 - from the file “Filter Gallery.8bf”
   Flash 3D 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Fresco 19.0 - from the file “Filter Gallery.8bf”
   Glass 19.0 - from the file “Filter Gallery.8bf”
   Glowing Edges 19.0 - from the file “Filter Gallery.8bf”
   Google Earth 4 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Graphic Pen 19.0 - from the file “Filter Gallery.8bf”
   Halftone Pattern 19.0 - from the file “Filter Gallery.8bf”
   Halide Bottlenecks 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “HalideBottlenecks.8bx”
   HDRMergeUI 19.0 - from the file “HDRMergeUI.8bf”
   HSB/HSL 19.0 - from the file “Standard MultiPlugin.8bf”
   IFF Format 19.0 - from the file “Standard MultiPlugin.8bf”
   IGES 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Ink Outlines 19.0 - from the file “Filter Gallery.8bf”
   JPEG 2000 19.0 - from the file “JPEG2000.8bi”
   Kurtosis 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Lens Blur 19.0 - from the file “Lens Blur.8bf”
   Lens Correction 19.0 - from the file “Lens Correction.8bf”
   Lens Flare 19.0 - from the file “Standard MultiPlugin.8bf”
   Liquify 19.0 - from the file “Liquify.8bf”
   Matlab Operation 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “ChannelPort.8bf”
   Maximum 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Mean 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Measurement Core 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “MeasurementCore.8me”
   Median 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Mezzotint 19.0 - from the file “Standard MultiPlugin.8bf”
   Minimum 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   MMXCore Routines 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “MMXCore.8bx”
   Mosaic Tiles 19.0 - from the file “Filter Gallery.8bf”
   Multiprocessor Support 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “MultiProcessor Support.8bx”
   Neon Glow 19.0 - from the file “Filter Gallery.8bf”
   Note Paper 19.0 - from the file “Filter Gallery.8bf”
   NTSC Colors 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “NTSC Colors.8bf”
   Ocean Ripple 19.0 - from the file “Filter Gallery.8bf”
   OpenEXR 19.0 - from the file “Standard MultiPlugin.8bf”
   Paint Daubs 19.0 - from the file “Filter Gallery.8bf”
   Palette Knife 19.0 - from the file “Filter Gallery.8bf”
   Patchwork 19.0 - from the file “Filter Gallery.8bf”
   Paths to Illustrator 19.0 - from the file “Standard MultiPlugin.8bf”
   PCX 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “PCX.8bi”
   Photocopy 19.0 - from the file “Filter Gallery.8bf”
   Photoshop 3D Engine 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Photoshop3DEngine.8bi”
   Photoshop Touch 19.0 - from the file “PSDX.8bi”
   Picture Package Filter 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “ChannelPort.8bf”
   Pinch 19.0 - from the file “Standard MultiPlugin.8bf”
   Pixar 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Pixar.8bi”
   Plaster 19.0 - from the file “Filter Gallery.8bf”
   Plastic Wrap 19.0 - from the file “Filter Gallery.8bf”
   PLY 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Pointillize 19.0 - from the file “Standard MultiPlugin.8bf”
   Polar Coordinates 19.0 - from the file “Standard MultiPlugin.8bf”
   Portable Bit Map 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “PBM.8bi”
   Poster Edges 19.0 - from the file “Filter Gallery.8bf”
   PRC 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Radial Blur 19.0 - from the file “Standard MultiPlugin.8bf”
   Radiance 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Radiance.8bi”
   Range 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Render Color Lookup Grid 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Export3DLUT.8be”
   Reticulation 19.0 - from the file “Filter Gallery.8bf”
   Ripple 19.0 - from the file “Standard MultiPlugin.8bf”
   Rough Pastels 19.0 - from the file “Filter Gallery.8bf”
   Save for Web 19.0 - from the file “Save for Web.8be”
   ScriptingSupport 19.0 - from the file “ScriptingSupport.8li”
   Shake Reduction 19.0 - from the file “Shake Reduction.8bf”
   Shear 19.0 - from the file “Standard MultiPlugin.8bf”
   Skewness 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Smart Blur 19.0 - from the file “Standard MultiPlugin.8bf”
   Smudge Stick 19.0 - from the file “Filter Gallery.8bf”
   Solarize 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Solarize.8bf”
   Spaces 19.0 - from the file “Spaces.8li”
   Spatter 19.0 - from the file “Filter Gallery.8bf”
   Spherize 19.0 - from the file “Standard MultiPlugin.8bf”
   Sponge 19.0 - from the file “Filter Gallery.8bf”
   Sprayed Strokes 19.0 - from the file “Filter Gallery.8bf”
   Stained Glass 19.0 - from the file “Filter Gallery.8bf”
   Stamp 19.0 - from the file “Filter Gallery.8bf”
   Standard Deviation 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   STL 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Sumi-e 19.0 - from the file “Filter Gallery.8bf”
   Summation 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Targa 19.0 - from the file “Standard MultiPlugin.8bf”
   Texturizer 19.0 - from the file “Filter Gallery.8bf”
   Tiles 19.0 - from the file “Standard MultiPlugin.8bf”
   Torn Edges 19.0 - from the file “Filter Gallery.8bf”
   Twirl 19.0 - from the file “Standard MultiPlugin.8bf”
   U3D 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Underpainting 19.0 - from the file “Filter Gallery.8bf”
   Vanishing Point 19.0 - from the file “VanishingPoint.8bf”
   Variance 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Virtual Reality Modeling Language | VRML 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Water Paper 19.0 - from the file “Filter Gallery.8bf”
   Watercolor 19.0 - from the file “Filter Gallery.8bf”
   Wave 19.0 - from the file “Standard MultiPlugin.8bf”
   Wavefront|OBJ 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   WIA Support 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “WIASupport.8li”
   Wind 19.0 - from the file “Standard MultiPlugin.8bf”
   Wireless Bitmap 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “WBMP.8bi”
   ZigZag 19.0 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
   com.adobe.inapp.purchase  2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
   com.adobe.Butler.backend  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
   New Document  2.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.ccx.fnft\fnft.html”
   Libraries  2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
   Start  2.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.ccx.start\index.html”
   Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
   Export As  3.0.13 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Installed TWAIN devices: NONE
if you can't :
Dave
Jan 15, 2018 Jan 15, 2018
Thank you Dave.
But i cant fix it.
it say that there is a problem With the drive
Hi
What exactly are you doing when you get the message saying you have a problem with the drive?
Did you follow the GPU troubleshooting steps in the link I gave you?
Dave
