Hi, I have Photoshop CS6 and I try to restore a script from a old save (Time machine). I look on Photoshop CS6/Presets/scripts but I can't find it. Do you know where it could be?
Are you sure you had a script a Name.jsx file not an action set SetName.atn file. Did you use it from Photoshop'd menu File>Scripts>ScriptName how did you use it from the Action Palette ActionName. Scripts can be executed from any folder they need not be in Phoroshop's folder PSversion\Presets\scripts\
I use Windows Mac Photoshop location and names. Mac locations and naming are somewhar different the Mac OS
On windows the scripts path for CS6 is not where I install my scripts I link that folder to my Photoshop Scripts tree.
Yes, I found it! It was on my Library (under my username) and it's a file name Actions Pallette.psp
Thank you!
I use Action palet but even if I use seach on my Mac, I cant find it
You should save the action sets your actions are in. So you will not loose them when your Photoshop preferences need to be reset.
Unless you save your action in action sets in *.atn files the only place your actions are stored is in your Photoshop preferences folder in your Action Palette Photoshop Preference file on my windows workstation that file:
"C:\Users\jjmac\AppData\Roaming\Adobe\Adobe Photoshop CS6\Adobe Photoshop CS6 Settings\Actions Palette.psp"
