Hi all
Personally I'd be a bit surprised if turning off the option
for ignoring subsequent terms does the trick. Actually, I'm
thinking in this case it would work against you by toggling off the
option.
It's my understanding that this feature operates on a term by
term basis. For example, let's say you have four terms in a topic.
Two are identical. One near the top of the topic and one near the
bottom. The other two are totally different. When enabled, the
first term encountered would be converted to a hotspot and the one
on the bottom would be ignored. But the other terms would also
become hotspots.
My guess here is that because Amy has both Market AND Market
Name, the wizard is seeing Market first and making that a hotspot.
So how does one expect the Hotspot Wizard to know when you want
just Market and when you want Market Name?
Note that in addition to the Hotspot Wizard, you may also
select text that you want to become hotspots, then click and drag
the term from the Glossary Designer to the selected text to create
the hotspot.
Cheers... Rick
