Hello,
How can I make an animated menu like this?
and then integrate it into Muse with possibility by adding hyperlinks on active state?
Publish as OAM File
Simply by learning to code web sites!
Muse isn’t the right tool for this.
Some parts can be done with using GIFs or OAM files which can be created with Animate CC and imported into muse. Or may be you can find somethig https://musewidgets.com/collections/widgets here
Thanks, I'd rather be able to do it alone with Animate,
more specifically, how should I do it, like button or clip and then how should I export it?
Sorry for the thousand questions
Should I move the question under Animate?
Publish as OAM File
