Change layer names so lowercase
Jan 17, 2018 Jan 17, 2018
Hey guys,
posting for the first time and i dont know any sort of scripting so would be helpful if anyone can help.
I want to change each and every layer names to complete lower case. Eg : Picture_Large.png >> picture_large.png
There around 1000 layers so i hope you understand the difficulty to change it manually. I found a script but it changes it to uppercase and only changes groups and not all layers. Here
Plz help
Actions and scripting
544
Adobe
Advocate ,
see if this is right for you
// written by Lukasz Wieczorek at http://lukasz.io
// Please do not remove this and give credit if you repost. Thanks!
var layerLength = app.activeDocument.layers.length;
var docRef  = app.activeDocument;
for(i = 0; i < layerLength; i++){
   docRef.activeLayer = docRef.layers
   var myName = app.activeDocument.activeLayer.name;
    var newName = myName.toLowerCase();
    docRef.activeLayer.name = newName;
Jan 18, 2018 Jan 18, 2018
ok so i ran your script and this what happened:
1. Only the artboard case changed to lowercase
2. All other unselected or hidden layers were affected.
3. Didnt changed the layers that were nested inside the groups.
People's Champ ,
aaaa()
function aaaa()
    try {
        var i = get_layer_count();
        var end = 1;
        var ret_ok = true;
        while (i >= end && process_layer(i)) { --i; }
        return ret_ok;
        function get_layer_count()
            try
                var r = new ActionReference();
                r.putEnumerated( charIDToTypeID( "Lyr " ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
                var ret, n;
                try { ret = executeActionGet(r);                       } catch (e) { alert(e); ret_ok = false; return 0; }
                try { n   = ret.getInteger(stringIDToTypeID("count")); } catch (e) { alert(e); ret_ok = false; return 0; }
                r = null;
                ret = null;
                try { app.activeDocument.backgroundLayer; } catch(e) { return n; }
                return n-1;
        function process_layer(n)
            try {
                r.putIndex( charIDToTypeID( "Lyr " ), n);
                var ret, s;
                try { ret = executeActionGet(r); } catch(e)  { alert(e); ret_ok = false; return false; }
                var name = ret.getString(stringIDToTypeID("name"));
                switch (ret.getEnumerationValue(stringIDToTypeID("layerSection")))
                    case stringIDToTypeID("layerSectionEnd"):
                        break;
                    default:
                        var name1 = name.toLowerCase();
                        if (name1 == name) break;
                        var d1 = new ActionDescriptor();
                        d1.putReference( charIDToTypeID( "null" ), r );
                        executeAction( charIDToTypeID( "slct" ), d1, DialogModes.NO ); // because of the bug at least in CS6 - CC2108
        // can't set layer name if layer is not active
                        ret = new ActionDescriptor();
                        ret.putString(stringIDToTypeID("name"), name1);
                        d1.putObject( charIDToTypeID( "T   " ), charIDToTypeID( "Lyr " ), ret );
                        executeAction( charIDToTypeID( "setd" ), d1, DialogModes.NO );
                        break;
                ret = null;
                return true;
            catch (e) { alert(e); ret_ok = false; return false; }
    catch (e) { alert(e); }
It worked!!!
Thank you so much
