I did some cinemagraphs in PS and it works very simple and well. The only thing I´m missing is how can I rewind (or play it reverse) a video clip in my timeline?
I was searching the web and found tons of tutorials about making cinemagraphs with PS but none shows how to let them play reverse.
I want to achieve an effect like I did in this cniemagraph (created with another software): Instagram
Michael
Here is a tutorial that explains how to do this very clearly
Let me know if you have any questions, happy to help
Sorry. I forgot to mention that I DON´T want to export a GIF but a mp4 video. Any suggestion how that works with regular video files?
Thanks again. I know how to export a video but as I understand the tutorial you mentioned earlier it is only for GIFs. So the rewind thing explained there is GIF only. Or do I miss something?
Reverse Frames is a feature in the timeline editor. You can right click on the frames and reverse them.
SO take your video clip, convert it to a frame based animation.
Duplicate the frames. Select the duplicated frames, right click, reverse frames.
If necessary convert back to video timeline also in the timeline pull down menu, ow export as video.
Now you can make a loop of the frames like in your sample instagram clip.
I must be blind. I don´t see the option to convert into frames...
At the bottom of the timeline if you see this then you are in the wrong timeline. You are currently in the video timeline. The icon converts to frame animation timeline. Click on it then go to the menu.
If you see this icon then you will see the menu item mentioned above. The icon means you are in frame animation and would like to convert to video timeline.
Hope this clarifies things.
I have theses three "dots" bottom left.
When I click on them I get a dialog telling me the timeline will be converted into a frame animation but video-layers are not played back in a frame-animation (German, sorry)
If I click "continue" (the blue button) this is the result
I´m getting nuts with this simple task.
Yes. It does not convert the animation correctly. Honestly on the video timeline there is no easy way to reverse. If you have the chance to use Animate or After Effects, it may provide more robust options. But let's do this is Photoshop. You have already created the animation on the video timeline.
Video Timeline
This may be the easiest thing to do. And just keep it in the Video Timeline.
If you feel you want to use the frame animation timeline then this may be a good process:
Frame Animation Timeline
Let me know if this answers your question.
Thanks Katie.
Now I got it and it works but it´s indeed way too complicated in my view. Such a simple task in a software like FinalCut but so complicated in PS. I know PS is not a video editing app but as it already has quite basic but nice video editing functions I would have expected it to have this simple function as well. To me playing a clip backwards is on the same level like playing it at 50% which PS can do very easy.
Any way no big deal because I don´t need the reverse function very often and if I need it I can do it in FinalCut before I switch to PS for the retouch or color grading stuff where PS is king.
You wanted to know what I try to achieve? Pretty simple. Take a look at my very first cinemagraph I created a few days ago by using FlickGraph which is incredibly simple to use but of course lacks all the great editing features of PS.
https://www.instagram.com/p/BeC19fDhgv8
Cheers
Michael
I love it!
You say Final Cut and probably mean Final Cut 7 which means you can use Premiere. Since CS 6 Premiere has used most of Final Cut 7 keyboard shortcuts. What is great with Premiere is that it picked up some amazing Final Cut 7 workflows but still kept its After Effects capabilities.
Try Premiere. I had mentioned Animate and After Effects as they are the true animation tools but Premiere is After Effects with a little less power. Try it... if you know Final Cut 7 then you know Premiere. (Premiere & Final Cut are considered video editors)
After Effects, Premiere, Animate, and Final Cut all make it easy to keyframe and reverse keyframes. The best tool for the job is always the one you can get the job in comfortably.
I mean FinalCut Pro X which works perfect for me when it comes to video editing. I know the Adobe stuff of course but to be honest I don´t like the pricing. I´m fine with 10 Euros a month for PS but that´s all I need from Adobe.
Final Cut X is great too. I’m actually an ACT too and teach both Premiere & X. Either one is fine for what you are doing. Think you got it covered!
There is another method for doing this. I recently released a photoshop panel I created that allows you to reverse video in photoshop just using one click. You can find it at this site: https://kofiamoa.photo/kp
This is the easiest I've seen so far -
Select the clip you want to mirror
Go to the top of photoshop and click Edit
Scroll down and Click Transform
Click on either Flip Horizontal or Flip Vertical
A box will pop up that asks if you want to convert it to smart object layer
Click Convert (may take a little time if you have a lot of graphics to flip)
Go back and play with the Timeline slider back and forth and watch the mirror magic happen!
Basically you are treating is as a layer and mirroring it like it was a single layer but it works with the whole clip ! : )
PS - This is Frank's mom, Joanne. I forgot I was logged into my son's adobe account until after it posted my reply.
NOTE: I forgot to add that once you convert the layer to the smart object layer it won't be as easy to edit.
