Hello! Is it possible that one day we will have a Radial Gradient in Camera Raw. I'm using a lot of RG in my daily work in Photoshop, it would be very useful in CR! thanks, Oleg
Have you tried Radial Filter (J)?
yes, I have tried..
By the way: This is a user Forum, so you are not really addressing Adobe here, even though some Adobe employees thankfully have been dropping by.
Photoshop Feature Requests should be posted over at
thanks, I posted there
If you use the radial filter and set it to "outside" and make adjustments (including color) then make a similar filter and set it to inside (and change the settings) you can achieve much of what a radial gradient will do, with the additional advantage that it does not need to be circular.
Dave
