I have Adobe InDesign CC 2017 installed on two computers, one with Windows 7 and the other with Windows 10. Unfortunately, every time I use Print Booklet on the computer with Windows 10 it fails with this error:
This problem never occurs on the computer with Windows 7, but our team members are upgrading to Windows 10 so I need to figure out how to get it to work on the new computers. I am still able to Export a PDF with the Adobe PDF printer, but just can not Print a Booklet. Is there a work around for this? Thank you!
Never mind. One of our IT members found a weird workaround for it. He had me go to Print Settings... from the Print Booklet menu and change the printer from Adobe PDF to our real office printer then clicked 'OK'. Went back in to Print Settings and changed the printer BACK to Adobe PDF and clicked 'OK'. It solved the problem. Wish I didn't have to do that, but it works.
I was having the same issue and used your fix above and it worked. Thank you--I was ready to pull my hair out!
OMG...thanks a million! We have had this issue FOREVER and could not figure it out. This worked perfectly...makes zero sense, but worked perfectly! Thanks so much!!!
i was ready to reinstall the application... ITS WORKED!!! Thank you for sharing..
Literally never had this problem until I was in a crunch for time...thanks for the fix. Ridiculous way to fix it, but spot on. Thanks again.
