In creating a PDF, I added a section for a signature. Whenever somebody signs the PDF, the signature is always rotated 90 degrees clockwise. I've tried making the properties of the signature box to rotate 270 degrees, but that does nothing to change the final orientation. Any help would be appreciated. Thank you.
I'm having the exact same issue. I also notice the dialogue box General > Common Properties > Orientation has the option to change the rotation from 90 to 0 greyed out so you cannot access it. So has anyone found a work-around solution?
