How do I enlarge the pre-set manager area so that I can choose a pattern or texture in Photoshop?
Click on the gear in the upper right corner of the Preset Manager and choose Large Thumbnail from the drop-down menu.
Then, to fill the screen with pattern options click here.
Thank you...however the three right hand buttons are not available to me. The picture may help. I can not select the pattern when the very small box appears (which is just above the white arrow in this pic). Appreciate more assistance. I would appreciate a phone call if possible! let me know and I can send my number.....I am desperate for this function.
Your screenshot did not upload, so we can't see what you are referring to. Drag your screenshot image into the reply window.
hope this works
Nothing so far. Try the Insert Image button on the toolbar.
attached
Whatever you are doing, it is not working. If you are using email to access the forums, try a web browser.
Even when I go into the preset manager and choose a pattern, it does not bring it into the little box where I can then manipulate it. I used to be able to see all my pattern choices on a double click in that white area. What has happened to this function?
Maybe you need to reset the preferences. See this thread: pattern preview box is so tiny
