Hi Rick:
Sorry about my delay in getting back to this.
I have found the solution to cleaning up unused objects (not just backgrounds). By the time i got back here, Lyonlover had also posted the correct solution.
The correct solution is to Select View->Library, at teh top of the library panel you have the Select unused and Garbage icons, however, you normally have to Drag the Library window larger to see them (hidden by default).
Once this is completed, the file size is realistic given the amount of interactions embedded.
As for the web server, I should have clarified "The SharePoint server" using the Checkout and Checkin tracking.
Best Regards,
Dennis
