Hi there,
I'm trying to save my PSD filed as a PDF which I can do successfully, however, when the PDF saves, it doesn't save as the full canvas size that the PSD working file is. This is important because when I go to print the files in the actual size, it doesn't allow me to because the canvas isn't the correct size.
Any idea or suggestions as to how I can fix this? I've already tried increasing the size of the PDF but the actual image stays the same size and instead the rest of the PDF creates a large canvas with white borders where the image is tiny in the middle.
Thans for your help on this!
How are you saving the PDF, though PS save as? I seem to have no problem. Can you post some screen shots?
More info required please. Source size of image in pixels, canvas size in inches/cm - saved PDF size in in/cm etc. is any content being cut off etc.
