CSH Calls for Merged CHM's
Jan 08, 2009 Jan 08, 2009
Is it possible to do a CSH call to a master chm that opens the topic in the slave CHM, but still shows the master CHM, I am trying to avoid making calls to seperate chm files and only want to call the master chm.
Would I need to edit the alias file so that path would point to the other chm? I show that in alias file it lists as nameofhelpfile\topic
Any one do anything like this? Or is Merged CHM and CSH not doable?
413
Jan 09, 2009 Jan 09, 2009
Welcome to the forum.
I don't know the answer to your question but I am sure it has been covered. Go into your forum settings and change the number of days a search covers and then poke around this forum.
Hi TrentSnake.
Yes you can. It requires you to create your master and slave projects assigning your mapids in the relevant projects. Merge the slave projects into the master project's TOC. Then you open the master project's .hhp file in notepad (having made the necessary sacriface to the backup god) and copy the entire [merge files] section to the clipboard. This is pasted into each slave project's .hhp file. You also need to add the master project's TOC as an alternate TOC in each slave project and add the master project's TOC to the baggage folder.
I have documented this whole procedure so if you need me to send you a copy, just shout.
Enthusiast ,
Jan 11, 2009 Jan 11, 2009
Hi, TrentSnake, and welcome,
Have a look at this thread:
Merged help projects and context sensitivity
This may also help:
http://forums.madcapsoftware.com/viewtopic.php?f=12&t=6463#p35098
Pete
RoboHelp Documentation
Download Adobe RoboHelp
