Hi all,
after the latest Ps update CC2018, Im not able to cycle between the open docs in photoshop any more.
Does someone knows where I can go to enable that shortcut?
Dragan
Was that maybe a shortcut you set up in the OS?
If I remember correctly the default Photoshop shortcut is ctrl-tab.
I can cycle between open documents in OS when using cmd-tab command in Mac, thats no problem, however my question was how to enable cycle between the open documents only within photoshop when pressing on ctrl ~. I was able to do that before the very last 2018 CC update, but now not any more.
Did you set up that shortcut yourself?
And I was not talking about cmd-tab, but ctrl-tab within Photoshop.
oh ok I see, ctrl tab is working indeed. Yes I had sat up that shortcut before to be cmd tilda for the same function, but cant remember any more how.
That may have taken some finagling because I think »Cycle through open documents« is not listed under Edit > Keyboard Shortcuts.
Ill have to check my deep memory, I know I added it somewhere as cmd tilda. Thanks for teh ctrl tab suggestion, its appreciated.
Maybe I am mistaken and the shortcut can be edited under Edit > Keyboard Shortcut, but if not I suspect it might be possible to use AppleScript and rig up something in the OS keyboard shortcuts.
Do you use that OS shortcut yet?
Because cmd-tab allows cycling through open applications for me.
I use cmd tab to swap between open docs in OS all the time, i dont know where I would be without it.
