Lightroom Classic - Desktop in Folders
Engaged ,
Jan 26, 2018 Jan 26, 2018
Hi
Using MacBook Pro- all up to date - Sierra and PS and LR Classic
I cannot work this out
In LR Classic, Folders, Desktop - images keep showing up in the desktop.
All these images I had previously imported or exported using the desktop
All the images have an exclamation mark against them, meaning they cannot be found
Screen shot provided
Do I just ignore it or select them and delete. If I delete them does this affect those I want to
keep in Lightroom?
Can someone explain this to me please as I cannot find an aswer anywhere.
I hope I have explained this ok
480
Community Expert , Jan 27, 2018 Jan 27, 2018
To prevent more of these exports from re-appearing in LR, make sure the option is not selected to "Add to Catalog".
To get rid of the unwanted (extra) image thumbnails that you currently have, just delete (remove) them from the LR Catalog... being sure that you are not deleting the main master version that you have been working on. Only the export copy.
If you do export images to your local disk without "Add to Catalog", LR will not display or manage these new copies within its Catalog. It doesn't
One possibility: you might have an option checked in your Export Location: Add to This Catalog.
In that case, the target location of your exports will appear in Folders, with those extra image versions inside.
Most people will probably regard such re-importing of exports, as redundant - and undesirable.
An export is somewhat disposable / ephemeral in its nature, also second-best in what you can do with it, compared with the full LR image it has been based on.
There are some special circumstances where this option might be useful, though - hence, this checkbox.
Engaged ,
Thanks Richard, I thought that may be the case but I am glad I checked
cheers
Images with exclamation point icons can be fixed following these instructions:
Adobe Lightroom - Find moved or missing files and folders
Do not delete these photos. Do not re-import these photos. Fix the problem as explained at the link.
Truly unwanted image thumbnails (e.g., those that are only present due to having re-imported exports) CAN simply be deleted from the LR database, though. No need in that case, to go through the "find missing file" procedure.
Engaged ,
Thanks dj for this informative information but as I said above, these are 'exported images to the desktop for emailing' not to come back into Lightroom. Once emailed I usually move them to trash.
Lately they are building up in LR under Desktop.
Is this normal?
What is the best way to clear this clutter,  as I do not need these images/previews of exported images, I already have the originals in LR
If you do export images to your local disk without "Add to Catalog", LR will not display or manage these new copies within its Catalog. It doesn't even remember that they exist. It does not know or care what happens to them.
BTW it is also possible to export photos from LR directly to email, if you want. You first need to enter your email account details into LR, as explained in Help. This method then operates completely on the fly - leaving nothing behind on disk, nor in the Catalog.
Engaged ,
Thanks Richard, this all makes sense
Cheers
