I was wondering how this gif was created?Gyazo - a7804d1c4f46dd6a373d9ac1fa78b4d9.gif I am hoping to be able t re-create something like that where the effect added on top of the gif is also moving.
How much do you know already?
Do you know how to make Frame Animations?
It helps enormously if you number the foreground layers with the same numbers as the frames.
Another duplicate of How do I add a rainbow 'filter' to a GIF (i.e color changing)?
Please do not start multiple discussions on the same subject, it will get negative reactions and reduce the chance of a good reply. If you do not understand the replies you get, please SAY SO.
It drives me crazy. You spend 15 minutes putting together an annotated response, only to find that someone has already said exactly the same thing in another thread. As often as not, the OP never revisits the thread, although I see that the OP has done so in response to JJ in the other thread.
Here's a question from me. I followed my own advice to produce this rainbow background. It is 403 pixels wide, and has 95 frames. I'd thought that with the soft edges it might be reasonably smooth, but it still has the frame animation flicker. It's also 8Mb, so is going to take a while to load. There are moments when it appears to move more smoothly, so what is the secret to flicker free frame animations? Is there some math that takes monitor refresh time into account? I doubt it, as it takes about four seconds to move 400 pixels — perhaps that is too close a relationship and speeding it up to three seconds with less frames would work better. In fact we often see very fast moving animations that appear to move more smoothly than they have any right to. Is there an answer?
