I am working with low Rez photos. I need them 300 dpi and at least 8” large. Is there a pixel dimension that I can request they use that would get me what I need? I don’t do enough photography to address this. And most photographers I ask don’t do printed work so they don’t know. Any ideas?
Hi kialua,
You’ve more or less answered your own question.
If you need 300ppi and want to print 8 inches in size, then the photos need to be 2400 pixels (300 x 8). I personally have had good results with 240 ppi, and an 8 inch print at 240 needs to be just 1920 pixels across.
Mike
Hi kialua,
Mike
Thanks Mike. As long as one of the dimensions is 2400 then it should work. But ppl is not the as dpi. I need 300 dpi for printing presses. Isn’t “ppi” pixels per inch for monitors? And ”dpi” dots per inch for printing presses?
You’re correct that ppi is for monitors and dpi for print. But for practical purposes we can consider them equivalent for calculating the required image size.
Mike
The DPI is dependent on the quality of the printing press and how many dots of ink per inch it is capable of putting down. Your low-res photos won't improve with more ink.
DPI, PPI or LPI -- what's the difference?
You can't make a photo 300 dots per inch. Photos are made of pixels and the resolution is defined as how many pixels per inch. Output devices such as printers measure how many dots of ink per inch they can put down.
Right, I cannot make low Rez photos acceptable for the printing press. I need to direct the people handing in photos to use a setting on their cameras which will allow me to have hi Rez photos. 2400 should do it for my purposes.
Thanks Mike and Jane-e!
The resolution of images is an obsolete notion inherited from paper photos and scanners of the twentieth century:
