I am consuming the Groupwise web service and want to search
the appointments based on value provided for a custom field. All
the other searches (date, subject, message) are working fine. The
only thing that does not work is search on the custom field. If I
search on the Custom field the service returns all records.
Following is the excerpt of the code. CFGWID is the field
that is sent to groupwise with an application generated value. I am
able to query the field but cannot filter appointments using the
CFGWID field.
<filter>
<elements type="FilterGroup">
<element type="FilterEntry">
<op xsi:type="xsd:string">eq</op>
<custom xsi:type="xsd:custom">cfgwid</custom>
<value
xsi:type="xsd:string">#arguments.AppMsgID#</value>
</element>
</elements>
</filter>
At this time there is only one entry in this filter. Any
ideas?
