Help My photoshop always opens in auto recovery and brings up a file that I want to get rid of (it is saved into auto recovery)
Hi Amanda
No that is not normal and usually happens if Photoshop has shut down incorrectly.
Dave
Hi Dave
Thank you!
Next big question ... what shall i do to stop this happening?
I have been saving files before closing and it shuts down when it feels like it anyway.
(I have de bugged my Mac too!)
I have a large range of imported fonts and imported pictures which I'm sure isn't helping, but where to start?
Perhaps you could try resetting your preferences to the default. This corrects a lot of weird issues like that. You can reset Photoshop's preferences from the Preferences dialog box as shown below, or follow these instructions to do it manually:
Mike
Oh Thanks! I will have a look at that…
Thank you so much Michael, it looks a bit epic for me!
First I will get an external hard drive and second I will attempt this!
Hi Amanda
Resetting preferences is not a big deal. The preferences are saved each time Photoshop closes and if it does not close down correctly, for example due to a crash, then they can become corrupt. Resetting takes them back to the 'out of the box' condition.
Dave
Hi again!
Ok, so …photoshop … preferences … general —— then I don’t see ‘reset preferences on quit’! …Do I press reset all warning dialogue to get that option?
I don’t want to muck up here and I so appreciate your help, thank you!
Are you using Photoshop CC?
On earlier versions you need to hold down Opt+Cmd+Shift when starting. The timing is tricky but if you get it right you will see a message to delete settings. Accept that and new preferences will be built
Dave
Hi Dave
Thank you, I’m still building up to doing that!
Actually I am using CS6 version of Photoshop with Mac OS High Sierra, perhaps they aren’t so compatible?
(I have had the software for a few years)
Amanda
