I have a problem in using lasso tool , when i select part it closes automatically before i finish selection
Any help !!!!
Window 10 64 bit
Mouse
Photoshop 19.1
Thanks for your effort
I'm happy to tell you that the problem finally solved
The problem from my graphic card ... uninstalled it and reinstalled its driver again solved the problem
Thank you so much
Have you tried a different mouse perhaps the left finger button is failing an Photoshop thinks its been released?
yes i tried another mouse and the problem still here
Are you using the normal lasso tool? See below I can even capture the lasso tool being used and not closed.. Windows 10 pro CC 2018....
With the Lasso tool, the minute you release the mouse button, the selection area will connect back to the starting point. You need to keep the mouse button held down until you get back to the starting point. The Lasso tool isn't the best tool to use for selecting objects especially as they get more complex. I'd give the Quick Selection tool a try. It's a bit easier and more forgiving to use.
And you can always add or subtract from/to the selected area using the lasso tool with the modifier keys Shift add and Alt subtract.
thanks for your reply
yes i know the usage of lasso tool
the problem that when i try to select with it .. i started with first point after that it makes selection looks like line to the left upper direction after that i can select normally .... i don't know the reason for that upper left selection .... the problem is the that part i make rectangle on it
Thanks for your reply
I know the usage of the lasso tool ... the problem occurs after updating the last Photoshop update .. when i put cursor and try to make selection ... firstly it makes selection looks like line to the left upper direction after that i can select normally ... i don't know the reason for taking that direction accurately firstly !!!!
Any help
I updated photoshop in work and worked prefectly without any problems
nut here in my pc the problem still here
If you have reset all tools and your Photoshop preferences at home Try uninstalling CC 2018 indcluding Preferences and then try installing CC 2018.
I uninstalled cc 2018 3 times and reinstalling it again
I guess that the problem because of a process called cephtml engine.exe but i tried to stop it fron task manager but i failed
do you know a way to stop this process ?
I know nothing about cephtml or know if is is causing you problem at home. Why would a module with HTML in its name be involved with the Lasso tool. Have you tried uninstalling CC 2018 and download and use Adobe cleaner then install CC 2018. Use the Creative Cloud Cleaner Tool to solve installation problems
It sounds like Photoshop is seeing the mouse button is being released. That is why I asked if you tried a different mouse. Are you using a wired mouse or wireless? It could be related to your system or mouse driver
Now i uninstalled and reinstalled again for the fourth time but the problem still here plus that the brush tool also its direction
to the upper left side only
I changed mouse yesterday and the problems still
THis is Adobe CEP HtML Engine and Brush tool direction
I dis a google search on CEPHTML and found this perhap you will see someting usefull in that thread
What is the "Adobe CEP HTML Engine"? It`s using too much from my processor.
that thread is very very good and i can stop CEP HTML Engine process but i/m sorry to tell you that the problems still here
Big thanks for your effort
I can't know what can we do else !!!
Thank you so much
Good to gear.
