End of jsx script let user choose when to finish
Engaged ,
Jan 28, 2018 Jan 28, 2018
We converted an ATN to JSX and in the ATN the STOP command was used.  STOP was converted properly but what is needed in JSX is that stop needs to wait for user to complete the task at that time.  The action leaves things running as is so user can finish and the Click PLAY to resume.  The user is using the select tool when the stop is done.
Any to do in JSX?
RONC
Actions and scripting
2.5K
Community Expert , Jan 29, 2018 Jan 29, 2018
The basic problem is Action stop brake the action into parts.  Each part is player by the user clicking the play button to play the next part of the action and the same document need to be the active document in the right state.
The easiest way to convert this type of action to a script is use X's action file to script then brake the script produced into the Action Parts.   If there are two stops in an action there would be three scripts.   ActionPart1 ActionPart2 ActionPart3. Instead of clicking
Adobe
Post your code (at least that working part with a problem) so I'll make modification. It's hard to talk about thing I don't see.
Advocate ,
if you want to intervene with a block
you have to put the block
example
step8 (true, true)
I completetly don't understand your answer to him
Advocate ,
Kukurykus
I think I understand that he would like to stop the script
with a stop like in the example below
//#target photoshop
// test.jsx
// Generated Sun Jan 28 2018 18:15:39 GMT+0100
cTID = function(s) { return app.charIDToTypeID(s); };
sTID = function(s) { return app.stringIDToTypeID(s); };
//==================== test ==============
function test() {
  // Crea
  function step1(enabled, withDialog) {
    if (enabled != undefined && !enabled)
      return;
    var dialogMode = (withDialog ? DialogModes.ALL : DialogModes.NO);
    var desc1 = new ActionDescriptor();
    var ref1 = new ActionReference();
    ref1.putClass(cTID('Lyr '));
    desc1.putReference(cTID('null'), ref1);
    executeAction(sTID('make'), desc1, dialogMode);
  // Unisci visibili
  function step2(enabled, withDialog) {
      return;
    desc1.putBoolean(cTID('Dplc'), true);
    executeAction(sTID('mergeVisible'), desc1, dialogMode);
  // Imposta
  function step3(enabled, withDialog) {
      return;
    ref1.putEnumerated(cTID('Lyr '), cTID('Ordn'), cTID('Trgt'));
    var desc2 = new ActionDescriptor();
    desc2.putString(cTID('Nm  '), "layer test");
    desc1.putObject(cTID('T   '), cTID('Lyr '), desc2);
    executeAction(sTID('set'), desc1, dialogMode);
  // Crea
  function step4(enabled, withDialog) {
      return;
    ref1.putClass(sTID("contentLayer"));
    var desc3 = new ActionDescriptor();
    var desc4 = new ActionDescriptor();
    desc4.putDouble(cTID('Rd  '), 174.000004827976);
    desc4.putDouble(cTID('Grn '), 70.2840457856655);
    desc4.putDouble(cTID('Bl  '), 70.2840457856655);
    desc3.putObject(cTID('Clr '), sTID("RGBColor"), desc4);
    desc2.putObject(cTID('Type'), sTID("solidColorLayer"), desc3);
    desc1.putObject(cTID('Usng'), sTID("contentLayer"), desc2);
  // Imposta
  function step5(enabled, withDialog) {
      return;
    desc2.putEnumerated(cTID('Md  '), cTID('BlnM'), cTID('SftL'));
  step1();      //
  step2();      //
  step3();      //
  step4(true, true);
  step5();      //
//                    test.main
test.main = function () {
  test();
test.main();
// EOF
"test.jsx"
// EOF
Ok, I feel stupid now you probably refer to some xbytor2​ script I didn't know and he possibly used but didn't mention...
Engaged ,
Have to blame everything on me not xbytor.  Sorry
RONC
Advocate ,
rechmbrs
I do not understand English very well
if you can explain yourself better on what you want to do
we can help you better
Engaged ,
Thanks for the response.
The script builds a diagnostic as it goes from step to step.  At a point in the script a decision has to be made.  The diagnostic is displayed for the script user to evaluate.  The user should be able to say that the diagnostic is good and that the script should continue on or the user should state that the diagnostic needs more work and the script should allow the user to use the eraser tool to fix the problem and then tell the script to use the corrected image to continue with the same steps as the good image was sent to.
Please ignore our script and just consider what I have stated.
RONC
That's easy but not with script you use. Consider following construction then:
#target photoshop
if (!$.getenv('continue') {
     alert('First steps of script'), $.setenv('continue', 1)
     // time to use eraser and continue script hitting button
     // or continue script with no prior action by hitting buutton
else {
     alert('Next steps of script'), $.setenv('continue', '')
if statement sets global variable to true. So next time (after script stopped and you used eraser or not) it checks that global variable is set to true. For the script it's command to execute else statement. So you pressed bound button and your script continued with else statement. After all steps of else statement are finished, script sets global variable back to false, so next time you run script it starts working again from if statement. That above sample is working, try it to understand me better...
Advocate ,
the script could be useful
I did not understand how to make it work
you could post an example.
This is already very clear example
You put all his steps from first one he uses in script to 74, and then 75 (which I guess choose Eraser Tool). While step 77, and all others there are you put to else statement. When you run script it goes thru all steps to step 75, then it stops. When you rerun script it continues working from step 77. And so on, when you run script once again it starts from step 1 to stop at step 75, to go further from step 77 when you use (or not) Eareser Tool and run script again. But will his script accept this change?
Here's an example done on @geppettol66959005 script who asked me privately to demonstrate how that could be used in his script. Second part is his original script you have to replace 8 steps part (at bottom of script) to this little modification:
if (!$.getenv('continue')) {
     step1();      // Crea
     step2();      // Unisci visibili
     step3();      // Crea
     step4();      // Selezione
     step5();      // Crea
     step6();      // Imposta
     step7();      // Selezione
else {
     step8();      // Unisci visibili
// script
// TEST
//==================== Azione 1 ==============
function Azione1() {
  // Crea
      return;
  // Unisci visibili
      return;
  // Crea
      return;
    ref1.putClass(cTID('AdjL'));
    desc2.putClass(cTID('Type'), sTID("vibrance"));
    desc1.putObject(cTID('Usng'), cTID('AdjL'), desc2);
  // Selezione
      return;
    ref1.putEnumerated(cTID('Chnl'), cTID('Chnl'), sTID("RGB"));
    desc1.putBoolean(cTID('MkVs'), false);
    executeAction(sTID('select'), desc1, dialogMode);
  // Crea
      return;
    desc3.putEnumerated(sTID("presetKind"), sTID("presetKindType"), sTID("presetKindDefault"));
    desc2.putObject(cTID('Type'), cTID('Crvs'), desc3);
  // Imposta
  function step6(enabled, withDialog) {
      return;
    ref1.putEnumerated(cTID('AdjL'), cTID('Ordn'), cTID('Trgt'));
    desc2.putEnumerated(sTID("presetKind"), sTID("presetKindType"), sTID("presetKindCustom"));
    var list1 = new ActionList();
    var ref2 = new ActionReference();
    ref2.putEnumerated(cTID('Chnl'), cTID('Chnl'), cTID('Cmps'));
    desc3.putReference(cTID('Chnl'), ref2);
    var list2 = new ActionList();
    desc4.putDouble(cTID('Hrzn'), 0);
    desc4.putDouble(cTID('Vrtc'), 0);
    list2.putObject(cTID('Pnt '), desc4);
    var desc5 = new ActionDescriptor();
    desc5.putDouble(cTID('Hrzn'), 73);
    desc5.putDouble(cTID('Vrtc'), 50);
    list2.putObject(cTID('Pnt '), desc5);
    var desc6 = new ActionDescriptor();
    desc6.putDouble(cTID('Hrzn'), 191);
    desc6.putDouble(cTID('Vrtc'), 218);
    list2.putObject(cTID('Pnt '), desc6);
    var desc7 = new ActionDescriptor();
    desc7.putDouble(cTID('Hrzn'), 255);
    desc7.putDouble(cTID('Vrtc'), 255);
    list2.putObject(cTID('Pnt '), desc7);
    desc3.putList(cTID('Crv '), list2);
    list1.putObject(cTID('CrvA'), desc3);
    desc2.putList(cTID('Adjs'), list1);
    desc1.putObject(cTID('T   '), cTID('Crvs'), desc2);
  // Selezione
  function step7(enabled, withDialog) {
      return;
  // Unisci visibili
  function step8(enabled, withDialog) {
      return;
  step1();      // Crea
  step3();      // Crea
  step5();      // Crea
  step6();      // Imposta
//                    Azione1.main
Azione1.main = function () {
  Azione1();
Azione1.main();
Engaged ,
I'm afraid we get a run time error 24 stating that either Step1(); or Step77(); is not a function.
I've marked our changes by comments.
HELP please,
RONC
if (!$.getenv('continue'))      // added extra )
  alert('First steps of script');   //changed , to ;
  // or continue script with no prior action by hitting button
  step1(true, true); // Stop
  step2(); // Flatten Image
  step3(); // Image Size
  //////////  step4-step70 removed from this not original
  step71(); // Set
  step72(); // Delete
  step73(); // Delete
  step74(); // Set Eraser
  step75(true, true); // Select
else
  alert('Next steps of script');  //changed , to ;
  /*      step76(true, true); // Stop    */  //remover from original per instructions
  step77(); // Set
  step78(); // Hide
  //////////  step79-step90 removed from this not original
  step91(); // Merge Layers
  step92(true, true); // Stop
Advocate ,
excuse my reflection
but you can not use it
step8 (false, false);
to skip the function
That what you did can't work, because you removed your functions (it's why you're getting that error), and left only steps() parts which call the (not existing right now in your current code) functions. Get back them so maybe that will finally work...
Beside you didn't understand my answer to @geppettol66959005​, who btw didn't understand too my last reply (what I'm seeing from his next private message). I didn't mean to replace whole code of him, but only a part to that code I posted:
step1();      // Crea
step3();      // Crea
step5();      // Crea
step6();      // Imposta
A shortened and more readable code won't work too, because there are no functions of your original script, steps call them:
     step71(); // Set
     step72(); // Delete
     step73(); // Delete
else {
     step77(); // Set
     step78(); // Hide
Engaged ,
I didn't remove the actual build of the steps.   I didn't send that part hoping it doesn't matter.
Can't I do this by just save a variable to disk and not using getinv and setinv.
Is there really a problem having true, true or false, false in a function call?
RONC
That won't change anything you save variables to disk or they will be part of environment. Problem with true, false in function I just solved other way to stop script and continue it, and it's not something I thought up, but xbytor2 so you should ask for him or someone who uses such scripts. If you kept functions in your script but didn't post them here and getting error that function doesn't exist then investigate why that happen. I can not be any of help when I don't see code.
The easiest way to convert this type of action to a script is use X's action file to script then brake the script produced into the Action Parts.   If there are two stops in an action there would be three scripts.   ActionPart1 ActionPart2 ActionPart3. Instead of clicking the Play button to  play the next part  of the action you run the next script part.
JJMack
Either 2 - 3 scripts, or just one with if, else if and/or else statement depending what is stored in 'env' at the time of running.
I find it better to store the data in the document metadata,  rather the in a global environment variable or a custom script option . Keep it with the document being worked one.   If you stop execution what to stop the user from  using the script or an action the user the script on an other document and mess with the environment variable or custom script option.
You also need to know how to code.  Not juste use X's actionfile to script to generate action manager code.
JJMack
I use both methods to store variables (env and meta), but here a problem is not a method but his ability to use anything that could work whatever he'll decide to use for raliability in future. For now he's figuring out what to do with given tips
Engaged ,
Feb 01, 2018 Feb 01, 2018
Thanks for the help.  After taking in all of the good information from you, we have the script working.  We broke it into portions and many of our problems went away.  Also decided to make the Action work to match script which will be much easier to understand for the users.
I hit the jackpot with this group.  JJ always has a few that helps so many.
My appreciation,
RONC
Engaged ,
This is part of code and sorry I misstated at end of script.
If STOP were at the end it works but unless we STOP it before step 77, the user doesn't have time to finish and no way to signal when finished so that the script can continue.
Sorry for my mixup.
See my comments in between code segments.
RONC
  function step74(enabled, withDialog)
      return;
    ref1.putProperty(PSClass.Channel, PSString.selection);
    desc1.putReference(PSKey.Target, ref1);
    desc1.putEnumerated(PSKey.To, PSType.Ordinal, PSEnum.None);
    executeAction(PSEvent.Set, desc1, dialogMode);
// Select
  function step75(enabled, withDialog)
      return;
    ref1.putClass(PSClass.EraserTool);
    executeAction(PSEvent.Select, desc1, dialogMode);
// We would like to complete this step or bypass it entirely with user saying so then continue to step 77.
// Stop usage came over from ATN so not same as what I said as they didn't try to bypass step 75
  // Stop
  function step76(enabled, withDialog)
      return;
    desc1.putString(PSKey.Message,
      "Stop for fixup.\r\rAfterwards, press Play to continue."
    desc1.putBoolean(PSKey.Continue, true); // Inserted by RONC  not correct???
    executeAction(PSEvent.Stop, desc1, dialogMode);
  // Set
  function step77(enabled, withDialog)
      return;
    ref1.putEnumerated(PSClass.Layer, PSType.Ordinal, PSEnum.Target);
    list1.putEnumerated(PSClass.Channel, PSKey.Red);
    desc2.putList(PSString.channelRestrictions, list1);
    desc3.putUnitDouble(PSKey.Scale, PSUnit.Percent, 100);
    desc2.putObject(PSKey.LayerEffects, PSKey.LayerEffects, desc3);
    desc1.putObject(PSKey.To, PSClass.Layer, desc2);
  step74(); // Set
  step75(); // Select
  step77(); // Set
There are two kinds of stops in Actions.   Stop and Stops with continue.  Both can stop the playing of the action and leave the Action position to start playing at the next step in the action after the stop step.  You can do anytime you want in Photoshop and when done click play to continue the action.  The difference between the two stops is the if you juste wanted to put our a message to the user Stop with conduce allows the user to just to acknowledge that they saw the mess by pressing enter and the action continues. That is like an alert in a script.  There is no concept stop in scripting where a script can be started from a different step.  You would need to program the script with some logic that would know what part of the script to run each time you run it.   I use the document metadata instruction field to record that information.  The first my scripts of this type does is look to see what it has recorded there. If it finds none of its recordings in there it know it the first time the script is being run on this document to do its stuff. So it runs part 1 which notes in the instruction field its information and ends execution which could be a message to the user to do something and run the script again.  The next time the script is run on the document the script will rune the next part. If part is the last part all of the scripts information will be removed from the instruction field and the scrip will end execution.  The  allows the full process  be done more the one time on a document.
My script all use the instruction field and do not interfere with each be preserving data in the field which is not theirs.    My scripts for the most part do not put out message and the user does not know they are using the script more than one.  Most of my scripts of the scripts of this type I have were written for use within Actions or toggle function for documents.   They are more or less like save and restore steps for action   One may save the resolution and ruler in use for the Document  in the instruction field. Than action  is free to  scale the document to a known size without reapplying. The resize a watermark for this size document or select a font size for this size document  add the text or watermark then run the script a second time to restore the document resolution  scale it back to it original scale..
However Adobe added a bug into scripting in CC 2015.5 and will not allow  you to set the instruction files back to null if it were null to begin with. So I set up script event manager new document and open document event to add garbage to the instruction field if it is not in there so the field will not be null.
Adobe add some strang bugs and makes statemnts like its bad to remove copyrights.  I do not understand that for they let your set the copyright to anything yow want to using Photoshop's file info.  I was jsut trying to set the instruction filed to what it was without the scripts information.
Jeffrey Tranberry, Sr. Product Manager, Digital Imaging
Official Response
Hi John, after some investigation, this new behavior is as-designed:
From the engineer: This was an intentional change to better preserve metadata during collisions from other applications:
"The new logic can lead to some cases where the user deleted information in another application and it reappears in Photoshop because it was not deleted in all instances (we have at least one source for the info, but no idea of the intention behind the change). But that is much safer than deleting added information which was intended (deleting a byline, description, or copyright is BAD)."
JJMack
