Hi I updated my cc cloud and I am still unable to use the select subject button,( it doesnt come up) I updated it again and when doing so lost all my actions and had to get my daughter to upload them for me. I noticed that they was another update yesterday in CC to fix problems which I updated. So why isnt it working and how do you check to see which version you have updated I believe it has to be 19.1.0 Thanks
The first thing to check is that the update installed OK. Go Help > About Photoshop you should see 19.1.0
You mention a Select Subject button. Do you mean the word 'Subject' does not appear in the Select menu?
Yes, it does not appear-After you select select & mask the Select- subject button isn't showing or in a drop down menu either
I have the same problem/iussue. The new "select subject" option is not present nowhere. I cecked my version number after the update, ofc and its 19.1. But on select menu, on select/mask window or in any selection tool....the command "select subject" (as i saw i many review) is not present. What i have to do? Thank you)
Yes even with their update it still doesn't work
