Hey all,
This started happening after I updated my Photoshop to the 2018 version, so every time I zoom out this happens:
The art board gets weirdly repeated and zoomed out, regardless if there's art on it or not. This only happens if I have any other tool besides the Move tool selected, but it gets rectified if I click the background with the Lasso or Move tool. I can still draw just fine, everything else works, but it's gotten a bit distracting and annoying when I'm working and constantly zooming in and out.
Anyone else have this problem with the new update? Please help! Thank you!
Hinatalieb,
Thanks for sharing this behavior with us. Does the issue persists if you uncheck "Use graphics processor" in the Photoshop> Performance menu?
Also, have you notices if the issue is limited to only zooming artboards and while using the Lasso or move tool?
Akash
Hi Akash,
I switch off "Use graphics processor" and it still does do this. It does this regardless of the tool I am initially using and the only way I can get rid of it is if I use the Lasso or Move tool and click on the background.
Thanks for the heads up natalieb,
Could you please help us with the Photoshop>> Help>>System info report so that we can check the app and system specs?
~Akash
Adobe Photoshop Version: 19.1.0 20180116.r.238 2018/01/16: 1153018 x64
Number of Launches: 18
Operating System: Mac OS 10.13.3
System architecture: Intel CPU Family:6, Model:69, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 2
Logical processor count: 4
Processor speed: 2400 MHz
Built-in memory: 8192 MB
Free memory: 4056 MB
Memory available to Photoshop: 6100 MB
Memory used by Photoshop: 70 %
Alias Layers: Disabled.
Modifier Palette: Disabled.
Highbeam: Enabled.
Touch Bar Property Feedback: Enabled.
Image tile size: 128K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Main Display
High DPI Monitor
Display Bounds: top=0, left=0, bottom=800, right=1280
OpenGL Drawing: Disabled.
OpenGL Allow Old GPUs: Not Detected.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=1
glgpu[0].GLVersion="2.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=1536
glgpu[0].GLName="Intel Iris OpenGL Engine"
glgpu[0].GLVendor="Intel Inc."
glgpu[0].GLVendorID=32902
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="Intel Iris OpenGL Engine"
glgpu[0].GLRendererID=16925953
glgpu[0].HasGLNPOTSupport=1
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[60]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2 (Oct 31 2017 18:30:00)"
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=1
clgpu[0].CLMemoryMB=1536
clgpu[0].CLName="Iris"
clgpu[0].CLVendor="Intel"
clgpu[0].CLVendorID=16925952
clgpu[0].CLDriverVersion="1.2(Dec 19 2017 21:05:44)"
clgpu[0].CLBandwidth=1.41248e+10
clgpu[0].CLCompute=161.211
nativegpu[0].NativeName="Intel Iris Graphics"
License Type: Subscription
Serial number: 90970366140334357975
GUIDBucket:
Application folder: /Applications/Adobe Photoshop CC 2018/
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 233.6G, 81.7G free
Required Plug-ins folder: /Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/Plug-Ins/
Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2018/Plug-Ins/
Installed components:
dvametadata.framework dvametadata 11.1.0.0
AdobeXMPScript.framework AdobeXMPScript 79.160451 79.160451
ICUUnicode.framework ICUUnicode 3.61 "gtlib_6.0" "." "21287"
ICUConverter.framework ICUConverter 3.61 "gtlib_6.0" "." "21287"
AdobeCrashReporter.framework AdobeCrashReporter 7.6.0
boost_system.framework boost_system 11.1.0.0
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeACE.framework AdobeACE 2.20.02.39705 79.589342
AdobeOwl.framework AdobeOwl 5.2.11
mediacoreif.framework mediacoreif 11.1.0.0
manta.framework manta 2.0.00.1 1.
dvaunittesting.framework dvaunittesting 11.1.0.0
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.8.0.34320 79.562390
k2.framework k2 1
AIDE.framework AIDE 1.5.0.36540 79.574279
dynamiclink.framework dynamiclink 11.1.0.0
dvametadataUI.framework dvametadataUI 11.1.0.0
UpdaterNotifications.framework UpdaterNotifications 10.0.0.1 "10.0.0.1"
AdobeExtendScript.framework AdobeExtendScript 4.5.8.1 81.1150526
boost_filesystem.framework boost_filesystem 11.1.0.0
AdobeBIB.framework AdobeBIB 1.2.03.39705 79.589342
AdobeXMPFiles.framework AdobeXMPFiles 79.160451 79.160451
AdobeLinguistic.framework 22175
dvaplayer.framework dvaplayer 11.1.0.0
PlugPlugOwl.framework PlugPlugOwl 8.5.0.87
AdobeAGM.framework AdobeAGM 4.30.87.39705 79.589342
adobe_caps.framework adobe_caps 10.0.0.6 1.584361
AdobeSVGRE.framework AdobeSVGRE 6.0 79.588619
AdobePDFL.framework AdobePDFL 15.0.0.38423 79.226411
dvacore.framework dvacore 11.1.0.0
AdobePIP.framework AdobePIP 7.4.1.109.46827
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.8.0.34320 79.562390
dvatransport.framework dvatransport 11.1.0.0
Cg.framework NVIDIA Cg
boost_signals.framework boost_signals 11.1.0.0
AdobeXMP.framework AdobeXMPCore 79.160451 79.160451
AdobeJP2K.framework AdobeJP2K 1.2.2.38423 79.266298
dvaaudiodevice.framework dvaaudiodevice 11.1.0.0
LogSession.framework LogSession 7.4.1.109.46827
PlugPlugExternalObject.framework 8.5.0.87
AdobeScCore.framework AdobeScCore 4.5.8.1 81.1150526
AdobeSVGAGM.framework AdobeSVGAGM 1.0.0.38473 79.582907
dvametadataapi.framework dvametadataapi 11.1.0.0
CITThreading.framework
WRServices.framework
amtlib.framework amtlib 10.0.0.221
AdobeBIBUtils.framework AdobeBIBUtils 1.1.39705 79.589342
boost_threads.framework boost_threads 11.1.0.0
aif.framework aif 6.0.00.1 1.
AdobeCoolType.framework AdobeCoolType 5.17.00.39705 79.589342
dvamediatypes.framework dvamediatypes 11.1.0.0
AdbePM.framework AdbePM 2.5.00.377243 1.578146
boost_date_time.framework boost_date_time 11.1.0.0
AdobeMPS.framework AdobeMPS 5.8.1.38423 79.582572
dvaui.framework dvaui 11.1.0.0
ahclient.framework ahclient 3.0.0.6
ICUData.framework ICUData 3.61 "gtlib_6.0" "." "21287"
dvamarshal.framework dvamarshal 11.1.0.0
Required plug-ins:
3D Studio 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Accented Edges 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Adaptive Wide Angle 19.1, © 2014-2018 Adobe. All rights reserved. - from the file “Adaptive Wide Angle.plugin”
Angled Strokes 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Average 19.1.0 © 1993-2018 Adobe. All rights reserved. - from the file “Average.plugin”
Bas Relief 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
BMP 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Camera Raw 10.1 (864), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Camera Raw Filter 10.1 (864), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Chrome 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Cineon 19.1.0 © 2002-2018 Adobe. All rights reserved. - from the file “Cineon.plugin”
Clouds 19.1.0 © 1993-2018 Adobe. All rights reserved. - from the file “Clouds.plugin”
Collada DAE 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Color Halftone 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Colored Pencil 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
CompuServe GIF 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Conté Crayon 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Craquelure 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 19.1.0 © 2003-2018 Adobe. All rights reserved. - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Crosshatch 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Crystallize 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Cutout 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Dark Strokes 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
De-Interlace 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Dicom 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “dicom.plugin”
Difference Clouds 19.1.0 © 1993-2018 Adobe. All rights reserved. - from the file “Clouds.plugin”
Diffuse Glow 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Displace 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Dry Brush 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Eazel Acquire 19.1.0 © 2007-2018 Adobe. All rights reserved. - from the file “EazelAcquire.plugin”
Entropy 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Export Color Lookup Tables 19.1.0 © 2012-2018 Adobe. All rights reserved. - from the file “Export3DLUT.plugin”
Extrude 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
FastCore Routines 19.1.0 © 1990-2018 Adobe. All rights reserved. - from the file “FastCore.plugin”
Fibers 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Film Grain 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Filter Gallery 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Flash 3D 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Fresco 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Glass 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Glowing Edges 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Google Earth 4 KMZ 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Graphic Pen 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Halftone Pattern 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Halide Bottlenecks 19.1.0 © 2018 Adobe. All rights reserved. - from the file “HalideBottlenecks.plugin”
HDRMergeUI 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “HDRMergeUI.plugin”
HSB/HSL 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
IFF Format 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
IGES 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Ink Outlines 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
JPEG 2000 19.1.0 © 2001-2018 Adobe. All rights reserved. - from the file “JPEG2000.plugin”
Kurtosis 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Lens Blur 19.1, © 2002-2018 Adobe. All rights reserved. - from the file “Lens Blur.plugin”
Lens Correction 19.1, © 2002-2018 Adobe. All rights reserved. - from the file “Lens Correct.plugin”
Lens Flare 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Liquify 19.1, © 2001-2018 Adobe. All rights reserved. - from the file “Liquify.plugin”
Matlab Operation 19.1.0 © 1993-2018 Adobe. All rights reserved. - from the file “ChannelPort.plugin”
Maximum 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Mean 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Measurement Core 19.1.0 © 1993-2018 Adobe. All rights reserved. - from the file “MeasurementCore.plugin”
Median 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Mezzotint 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Minimum 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
MMXCore Routines 19.1.0 © 1990-2018 Adobe. All rights reserved. - from the file “MMXCore.plugin”
Mosaic Tiles 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Multiprocessor Support 19.1.0 © 1990-2018 Adobe. All rights reserved. - from the file “MultiProcessor Support.plugin”
Neon Glow 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Note Paper 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
NTSC Colors 19.1.0 © 1993-2018 Adobe. All rights reserved. - from the file “NTSC Colors.plugin”
Ocean Ripple 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
OpenEXR 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Paint Daubs 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Palette Knife 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Patchwork 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Paths to Illustrator 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
PCX 19.1.0 © 1989-2018 Adobe. All rights reserved. - from the file “PCX.plugin”
Photocopy 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Photoshop 3D Engine 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “Photoshop3DEngine.plugin”
Photoshop Touch ©2013-2018 Adobe. All rights reserved. - from the file “PSDX.plugin”
Picture Package Filter 19.1.0 © 1993-2018 Adobe. All rights reserved. - from the file “ChannelPort.plugin”
Pinch 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Pixar 19.1.0 © 1989-2018 Adobe. All rights reserved. - from the file “Pixar.plugin”
Plaster 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Plastic Wrap 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
PLY 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Pointillize 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Polar Coordinates 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Portable Bit Map 19.1.0 © 1989-2018 Adobe. All rights reserved. - from the file “PBM.plugin”
Poster Edges 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
PRC 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Radial Blur 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Radiance 19.1.0 © 2003-2018 Adobe. All rights reserved. - from the file “Radiance.plugin”
Range 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Render Color Lookup Grid 19.1.0 © 2012-2018 Adobe. All rights reserved. - from the file “Export3DLUT.plugin”
Reticulation 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Ripple 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Rough Pastels 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Save for Web 19.1, © 1999-2018 Adobe. All rights reserved. - from the file “Save for Web.plugin”
ScriptingSupport 19.1.0, © 2002-2018 Adobe. All rights reserved. - from the file “ScriptingSupport.plugin”
Shake Reduction 19.1, © 2014-2018 Adobe. All rights reserved. - from the file “Shake Reduction.plugin”
Shear 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Skewness 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Smart Blur 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Smudge Stick 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Solarize 19.1.0 © 1993-2018 Adobe. All rights reserved. - from the file “Solarize.plugin”
Spaces 19.1.0, © 2015-2018 Adobe. All rights reserved. - from the file “Spaces.plugin”
Spatter 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Spherize 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Sponge 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Sprayed Strokes 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Stained Glass 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Stamp 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Standard Deviation 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
STL 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Sumi-e 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Summation 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Targa 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Texturizer 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Tiles 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Torn Edges 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Twirl 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
U3D 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Underpainting 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Vanishing Point 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “VanishingPoint.plugin”
Variance 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Virtual Reality Modeling Language | VRML 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Water Paper 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Watercolor 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Wave 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Wavefront|OBJ 19.1.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Wind 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Wireless Bitmap 19.1.0 © 1989-2018 Adobe. All rights reserved. - from the file “WBMP.plugin”
ZigZag 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.Butler.backend 2.0.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.Butler.backend/index.html”
com.adobe.inapp.purchase 2.11.27 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/purchase.html”
New Document 2.1.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.ccx.fnft/fnft.html”
Libraries 2.11.27 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/index.html”
Start 2.1.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.ccx.start/index.html”
Adobe Color Themes 6.1.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
Export As 3.1.2 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html”
BrushBox 2.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.derrickbarth.brushbox/ext_1”
Installed TWAIN devices: NONE
