When the project was originally created (back about RH v9) it
was decided not to keep all the images in the root directory. We
normally save our images to our Images folder, then Browse to that
directory to add it into the first topic. Once referenced in the
topic, it is listed in our Images folder, as you said with the two
Images hierarchy. This has worked fine up until this upgrade to
RH7.
I also thought naming confusion might have been the case,
which is why I tried renaming the Images folder to a variety of
different things. However the only one that seems to stick is Img2.
I've also belatedly remembered to check another images
directory, which is located a couple of folders down (this is for
admin specific images). This is also missing files. And again, the
only folder name that correctly displays all images after deleting
the cpd is Img2. (why do I always find the weird things??
The current project is probably too big to share easily. I'll
see if I can recreate in a new project, but I suspect I won't be
able to. I'll let you know how it goes.
Edit: Okay, with the admin images folder, if I rename it
Images, I get a few more images than when it is Admin_Images. Img3
also seems to give me the full list, while Img1 gives me the same
list as Admin_Images...I think I'm getting more confused.
