is it normal that the option flow for the clone stamp tool shows only an viewable effect between flow 1 to 10%. I have test it from a totally black area and use in clean white area and the results from 100% flow till down to 20% flow looks nearly the same.
I have next time painted black lines with the same flow to compare and I see even bigger differences.
Kind regards Frank from Germany (sorry for the english)
What’s the Spacing for the two (see Brush Settings)?
Thank You so much. That was the mistake (brush 25 and clone stamp 1) Have fixed in my head.
It’s not really a »mistake«, each of the two settings probably makes sense under certain circumstances.
i mean the mistake in my head 😉
