I am attempting to create a form with fillable fields. Prior versions of Adobe would suggest an auto-detection option (though a dialog box that appeared) which saved quite a bit of time. My current version of Adobe (Acrobat X Pro) does not seem to have this feature. Any suggestions would be appreciated. It is way too time consuming to add each field one by one. Is it possible that I somehow have this feature turned off? I have attempted it with multiple documents with the same result.
Thank you for your time.
Liz
It is "Prepare Form".
When you go to Form Edit mode it will automatically ask you whether to try
to create fields, if there aren't any in the file already.
Thank you so much for your quick reply. I do not see a Form edit option, this is all that I see.
Any additional suggestions are appreciated.
Thank you very much.
That's not Acrobat X, it's Acrobat DC... Anyway, in that version it's the Prepare Form command.
Thank you very much. My apologies for any confusion, it looks like I have both Acrobat X Pro and Acrobat Distiller DC installed on my machine. Do you suggest removing one? If yes, which one.
Depends on your needs and your OS. Acrobat X is outdated and not compatible with Windows 10, for example.
Is there another way to access those automatic prompts for the form fields. I notice I was able to access them even up through last year just by scrolling to that page in the document. Is there a way to bring that feature back?
