Making .jpg default
Contributor ,
Jan 31, 2018 Jan 31, 2018
My PE defaults to the horrible and large .bmp. How on earth do I change it to .jpg ????
382
Adobe
Engaged ,
To my knowledge, you can’t change the default “Save as” but what you can do is edit the default for ‘Quick Export As’
Edit > Preferences > Export
Type > Jpg
Then what you select the layer you can quickly save it in the desired format.
Alternatively, you can also do this;
Press Ctrl/command+Shift+Alt+S to save for web. It will remember the settings so you can change quality, file type (png, gif, jpg, etc).
EDIT: i think i've misunderstood the question...
Contributor ,
thanks charles,a nice quick reply. Once I have processed an image and want to save it, then select location, the default is .bmp. That is when I wanted to change but there is an alternative which you have touched on. "save as web" - which is where 99% on my images end up in web sites.
It still does not answer my question but it IS an alternative. Save as web is next to the save as - but when I open it after I had set it to .jpg, another window says .gif at 60%. I set it for jpg but it has gone when I eventually come back in.
OK I can work around that I suppose. But I would like save as to be defaulted to .jpg so I dont have to keep removing .bmp.
THANKS
Engaged ,
You can’t change the default ‘Save as’ it will always save as a PSD, since you’re saying the default is .bmp I think you’re doing something different or I’m missing some information.
Could you post a few pictures and maybe a roadmap of your path E.G: File > Save as > default .bmp
