Could not complete your request.
Jan 31, 2018 Jan 31, 2018
Hi everyone;
My first post.  Since installing the latest update to Photoshop 2018 a few days ago, I have been able to open one photo and since then I have the message below.
Would anyone have a possible solution?
Cheers!
-Al
996
Adobe
Feb 01, 2018 Feb 01, 2018
Without system information nobody can tell you much. Start by checking the usual suspects - graphics driver, screen configuration, related PS preference settings.
Mylenium
Hi alaind6361345​,
your problem could be similar to this thread: https://forums.adobe.com/thread/2443449
(mostly written in german language)
There is a checklist you can go through step by step (and the solution in the other thread was: to change the workspace eg to Essentials)
When the window is big enough and if you already work in this workspace try to reset this one (menu: Window --> Workspace -> Reset "your workspace") or change to another workspace.
By the way:
Do you use palettes which are not out of box was installed?
Thank you very much for your looking into this.  Indeed, changing the work space to "essentials" has solved the problem.  I was using "photography".  This never happened before and I hope a fix will come shortly.
Thanks again!
Al
You're welcome.
Blackcollar  schrieb
… and I hope a fix will come shortly …
I never heard, that the problem comes again. That's why …
Feb 28, 2018 Feb 28, 2018
For anyone who wants to get to know why it happens check: There isn't enough room to display this document => bug !
I found the solution to my problem though it may not be applicable to all.  I moved the tools bar from the right back to the left as per the original layout.  Every time I move the toolbar to the right, the same problem occurs.
Hope it helps others
Al
That's not everything what happens. When you choose 'View / Fit to Screen' a window is going to be moved to the bottom!
