> I have a problem that when a parent creates a new child,
this child should
> appear to the other parents when they login. These
parents are those who have
> been given permission by the original parent.
That doesn't sound like "a problem", it sounds like "a
requirement". It
doesn't become a problem until you actually try to implement
a solution,
and something goes wrong.
"A problem" would be along the lines of "I tried to do it
[some way], and
as a result of this [something occurred which is
undesirable]".
Your question is vague, and pretty much seems like you want
us to design
your system for you: you don't say which bits of the
requirement you're
struggling with, so one kind of needs to assume "all of it":
the DB design,
the SQL, the CF code, the UI... That's not the scope of a
question on a
forum, it's the scope for engaging a consultant.
Can I recommend you give it some thought, come up with an
approach, and
then ask if it's a reasonable one. Or possibly even try to
implement it,
and if you come across specific problems, sing out.
Adam
