Adobe Muse does not work, when i open a file and want to import something then i can't do anything any more, already restarted my mac and it stays the same.\
What to do???
Help
There must be an issue outside of Muse:
Your ai file is working completely correct.
What I did:
In no situation I encountered an issue.
One problem: The ai file is created in CMYK colour mode. The web doesn’t know
...Copy link to clipboard
Need t have some more info for a detailed investigation on your issue.
ISS it happening with any one particular file or any new file?
Any particular objects you trying to import?
What exactly you mean by does not work, does it crashes or freezes?
Ankush
Hello Ankush
It's with different files, that are new files. I wanted to upload an ai.doc.
It freeze.
Greetings Esther
What exactly does it mean, "import files"?
Normally you do not import a "whatever.doc" file to muse. You simply drag out a text box and write into this.
You could copy and paste text from a … . doc to the text box of muse.
Best Regards,
Uwe
Hi esther,
I am guessing by .ai doc, you mean an illustrator file!
How are you importing the file, is it in .svg format or plain .ai file?
Ankush
hello Ankush
Plain ai file, i alway's do.
Regards, Esther
Could you please share one of these „misbehaving“ .ai files with us via Dropbox, CC Files, or a similar file sharing service?
i tried to import a jpg and that worked. i want to send it with wetranfer but were can i send it??
You can create a public link and put it here so we can download.
More instructions can be found here - Please Provide a .muse File to Help Us Fixing Your Issue!
What I did:
One problem: The ai file is created in CMYK colour mode. The web doesn’t know CMYK. The colour mode has to be RGB. But this shouldn’t cause Muse to freeze. But anyway: Convert the ai graphic to RGB in Illustrator and try again.
thanks for you info and help, i try it again. Make it RGB and hope everything works then
greetings Esther
