2D Photo to 3D Environment and add object
Feb 02, 2018 Feb 02, 2018
So Im turning this pixelphoto into a 3d environment using vanishing points and then returning the 3D Layer to Photoshop. Cool, I now have kind of a 3D environment. But then I try to add a 3D object to it and the environment doesnt seem to catch shadows or reflections.  To be exact Im turning a corridor into the 3D Environment and I want to add a character to that corridor and I want his reflection to hit the ground floor and his shadow to be going up agains one of the walls.
Plus the character gets distorted like crazy when I merge the corridor and the character 3D objects. What am I missing guys
391
Adobe
Can you post screen shots?
So here i have opened the corridor pixelphoto. used vanishing points and returned them as 3D to Photoshop. Sent in my character and merged the meshes. isnt the walls, floor and ceiling now seperate 3D Objects and should catch shadows?
No. Vanishing point doesn't create a 3D image, it just lets you edit an image according to the grid you create in the vanishing point UI. You have to modify the shadows that you create with your 3d model to fit the 2D image.
Feb 03, 2018 Feb 03, 2018
When you take the image across from vanishing point it creates a  box model and  the scene is an "Unlit Texture" You can change this in properties to Solid but everything will go dark as the lighting is on the outside of the model
So you also need to go through each of the sides, top and floor and turn off cast shadows
You can then light your scene and walls and floor will catch the shadow from the second model.
Dave
Feb 04, 2018 Feb 04, 2018
Learn something new every day, Dave, well almost.
It only came to me after scratching my head for a while over the same issue a few months ago .  Actually my description was slightly wrong when I described it as a box model. The sides are in the shape of a box but are actually separate 3D "postcards".
Dave
