You'll have to try very hard to regain some of that patience
you've lost, or you'll continue to shoot yourself in the foot.
If links are working in preview mode, but not in the
published output, then some files have obviously not made the
transition from source-to-generatelocation-to-publishlocation.
Did you rename the project, and was that done outside the
RoboHelp project?
- Not good.
Are you generating output to the default !SSL! folder?
- Try generating to something like C:\TestOutput.
Are you generating with an incorrect Conditional build tag?
- In the Project Manager pane, right click each build tag and
select Properties to see which topics it's used in. Then see if
there's a Conditional Build Expression on the first window.
Pay particular attention to the pathname/filename values in
the first window of the Generate wizard, and to the publishlocation
value in the last window.
Come back with more details if none of this helps.
Good luck,
Leon
