I downloaded this brochure mockup today - but I can't seem to figure out why the turning page isn't showing the design layer. As you can see from the layers panel, I have imported both designs into layers A and D. However B and C are not smart object layers. I would like the middle turning page to have a different design on either side, but I can't work out how to do this! I'm getting really frustrated with myself!
Also, what does 'click & update' on the two green layers? Do I need to edit those layers so show designs (how?).
Thank you
Kelly
Running MacBook Pro 2012 Version 10.13.2
Adobe Creative Suite CS6 Photoshop
You are showing a frame 8 in a Frame animation. The layers that are visible in the layers palette create that frames composite. So check the layer which to see which layer are set visible for that frame, You need to scroll the layers palette to see if other layers need to be made visible You have two layer targeted in the layers palette neither is visible in frame 8.
Hi, thanks for your reply. Yes all correct layers are visible. Layers B and C never appear in the page turning animation. What does the click & update layers mean?
So layers A B C and D you do not want visible in frame 8 so what is wrong with frame 8?
No nothings one with frame 8 in particular, layers B and C do not appear on any frames, and I’m trying to figure out why
I see that in the layer palette that layers A,B,C and D visibility is off in frame 8. They should not show in Frame 8 and you write they do not show so what is wrong? In the frames you want them visible you need to turn their visibility on. Target the frame and turn the layers visibility on in the layers palette, The frame's content will be generate using the visible layers stack composite additionaly you can move layers positions. This frame animation as two layers and the layers are visible in all frames.
