Hi I am using Photoshop 2018 in Windows 10 and recently the Paths pop up window has stopped showing up. Does anyone have any suggestion son how to fi this problem?
Hi
I'm not sure what you mean by the paths pop up window. Is it:
a. The Paths Panel
b. The menu that opens when you right click the path in the paths panel
c. One of the drop down menu's from the option bar
d. The menu you get when you right click on a path
e. Something else
Dave
Thanks for your reply. I meant the Paths Panel which is meant to show when
you go to Window and then Paths. I hope this makes my original questiin
clearer.
Hi
OK The paths panel may have been moved off the screen or be hidden behind another element.
Try going to the top right of the options bar - click the down arrow and reset your workspace
If that doesn't bring it back - change your workspace to "Essentials" and then reset "Essentials"
Dave
Thanks for your reply. I reinstalled photoshop before I saw your message.
