I've been using Photoshop's Trim and Resize image and I realized that it always deletes unwanted pixels of my .psd document.
What can I do to have a more accurate Trim / Resize on my documents? I believe the cause of this is due to Resize.
The script is very simple:
doc = app.activeDocument;
// trim
doc.trim(TrimType.TRANSPARENT);
// ========== set units to pixels ==========//
var oldPrefs = app.preferences.rulerUnits;
app.preferences.rulerUnits = Units.PIXELS;
DocTrimmedWidth = doc.width;
DocTrimmedHeight = doc.height;
// resize algorithm
if (DocTrimmedHeight > DocTrimmedWidth) {
doc.resizeImage(undefined, UnitValue(1024, "px"),72, ResampleMethod.BICUBIC, 100);
else {
doc.resizeImage(UnitValue(1024, "px"), undefined, 72, ResampleMethod.BICUBIC, 100);
doc.activeLayer.applyOffset(0,512, OffsetUndefinedAreas.WRAPAROUND);
I tried different kinds of ResampleMethods to no avail. Here's the .psd I'm using it on:
ImproperResize.psd - Google Drive
There are always transparents pixels appearing on the .psd. What can I do about this problem?
https://i.imgur.com/TZc36yG.png
Try using this plugin for the resize
You can call this plugin in the script using the following function
function c3c_resize(w, h, sharp, use_contrast)
try {
if (sharp == undefined) sharp = 0;
if (use_contrast == undefined) use_contrast = false;
var old_units = app.preferences.rulerUnits;
var doc = app.activeDocument;
var w0 = Number(doc.width.value);
var h0 = Number(doc.height.value);
while (w > w0 || h > h0)
doc.resizeImage(UnitValue(4*w0,"px"), UnitValue(4*h0,"px"), doc.resolution, ResampleMethod.NEARESTNEIGHBOR);
app.preferences.rulerUnits = old_units;
var d = new ActionDescriptor();
d.putInteger( charIDToTypeID( "Wdth" ), w );
d.putInteger( charIDToTypeID( "Hght" ), h );
d.putBoolean( charIDToTypeID( "cC3P" ), true );
d.putBoolean( charIDToTypeID( "cC3F" ), false );
d.putEnumerated( charIDToTypeID( "uc3S" ), charIDToTypeID( "tc3U" ), charIDToTypeID( "uc30" ) );
if (use_contrast == true)
d.putEnumerated( charIDToTypeID( "mc3S" ), charIDToTypeID( "tc3M" ), charIDToTypeID( "rc31" ) );
else
d.putEnumerated( charIDToTypeID( "mc3S" ), charIDToTypeID( "tc3M" ), charIDToTypeID( "rc30" ) );
d.putInteger( charIDToTypeID( "pC3S" ), sharp );
d.putInteger( charIDToTypeID( "pC3W" ), w );
d.putInteger( charIDToTypeID( "pC3H" ), h );
executeAction( stringIDToTypeID( "5f3d6843-d895-44c2-bbb7-b71ca0cb8c01" ), d, DialogModes.NO );
return true;
catch (e) { alert(e); return false; }
Great, thanks for the help r-bin. I'll try this out in an hour when I'm back home.
Please change the line in the function
to
d.putBoolean( charIDToTypeID( "cC3P" ), false );
This guarantees the exact final dimensions W and H that you set.
This parameter tries to keep the proportions fitting on only the width
It works great, thanks Much appreciated!
I tried to use it on mac
with photoshop cs6 cc cc2014 does not work?
It's strange. On a mac I can not say anything. Write to the author.
