Cannot open my PS file with layers - Could not complete your request because of a program error
Feb 05, 2018 Feb 05, 2018
I have been working on a file and now I cannot open it the message is - Could not complete your request because of a program error. Can anyone help? Why has happened to my file. I reset my preferences but that did nothing?
1.3K
Adobe
The file may be corrupt.  There are some downloads on the web for programs that try to fix broken layers files.   I would first copy the bad file and try to fix the copy. You could upload the file to file sharing service like dropbox and post a link to it so other can test if they can open the file.
JJMack
Here is the link I put the files in dropbox? I don’t know how to reply back on the forum? First time…
https://www.dropbox.com/s/ufym051sxysb11a/brochure_8.5x14_double-gate-fold-sample%20front?dl=0
Kim Hunter
You may be in luck.  The file has no extension.  So  I gave it one .PSD Photoshop stated wrong.  So I looked into the file the first thing I saw was PDF.  I never save PDF file from Photoshop so  I changed the file extension to .pdf Photoshop said
JJMack
Thats perfect can you help me? How do I change the extension? What program do do that in?
Kim Hunter
Your file has a vert long file name
"brochure_8.5x14_double-gate-fold-sample front.5x14_double-gate-fold-sample front.5x14_double-gate-fold-sample front"
That is a hell of a long name for someone like me the can not type.  I just remane the file to "brochure.pdf" and Photoshop CC 2018 had no problem openong it with the exception of Fonts I did not have installed one my machine. I could have kept your full named and added the .pdf.
JJMack
One more thing - I can’t open the file I get an error so how do I change the file extension?
Kim Hunter
Mentor ,
Your file name has a period in it. Select the file name, and hit F2, and remove the part after the . and replace with "pdf".
brochure_8.5x14_double-gate-fold-sample front.pdf
You may need to display the extensions in Windows.
1) open an Explorer window (windows key - E)
2) File--> Options.
3) View tab, Advanced settings: UNCHECK "Hide extensions for known file types".
Now select your file, and hit F2, and rename to brochure_8.5x14_double-gate-fold-sample front.pdf
If Windows warns you about renaming the extension, confirm the action. Open in Photoshop.
But Photoshop threw an error when I attempted to open it. (CC2017)
It displays fine in my PDF viewer. PhotoLine opens it too.
I use a MAC computer. I was able to remove the . In the name and rename it with psd as the extension but when I try and open it in Photoshop it tells me - Could not complete your request because it is not a valid Photoshop document.
Any other suggestions?
Mentor ,
It's not a Photoshop document, but a PDF file. Try opening your file in a PDF viewer - such as Acrobat. Illustrator does open the pdf. But you may find that parts have been flattened here and there.
I am unsure how JJMack got it to open in Photoshop - it fails for me, and throws an error.
Good news I went back a couple weeks in my backup and I was able to pull up my file with all the layers and I have since saved it as a PSD file.
Thanks for everyones suggestions.
Your OSX most likely is hiding known File extension on you. Microsoft also does that by default . I change the default I'm a big boy I can handle  extensions and I like to know what one my machine I want to see what on my machine so I can work and not be blind.
JJMack
I see you have all my layers on the file you pasted? How do I get that back as a PS file?
